dist. wiring
Old Apr 4, 2014 | 10:12 PM
namvet6869's Avatar
namvet6869
Default dist. wiring
If you get rid of the comp. dist. and carb on an 81, is the wiring there for the dist.??? Might change mine over but am lost when it come to wiring dist.
Old Apr 4, 2014 | 10:30 PM
TimAT's Avatar
TimAT
It is. The pre-ECM distributor has 2 connections from external sources- TACH and BAT. Both of those exist on the post-ECM distributors too. Post-ECM, there is also another connector that is for the advance and retard that is all done by the ECM.
You'll need to pick up vacuum from the carb for the vacuum side of the advance.
Old Apr 5, 2014 | 12:03 PM
namvet6869's Avatar
namvet6869
I am confused. if I remove the ecm and keep the original dizzy, how will the advance work?????
Old Apr 5, 2014 | 01:01 PM
TimAT's Avatar
TimAT
The pre-ecm distributors used a combination of vacuum and mechanical advance mechanisms.
To dist. wiring
