Gear stick knob
Old Apr 5, 2014 | 01:33 AM
parabd69's Avatar
parabd69
4th Gear
Default Gear stick ****
hi, can somebody be able to tell me how to get the gear **** off a 1974 auto vette?
Old Apr 5, 2014 | 05:01 AM
parabd69's Avatar
parabd69
4th Gear
thanks, Dumb Aussie
Old Apr 5, 2014 | 10:56 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by AutoWiz
unscrew the button in the middle, then unscrew the handle
Catch the spring under the button.
Old Apr 21, 2014 | 05:29 AM
parabd69's Avatar
parabd69
4th Gear
Default water pump
hi again, can i swap a short neck with a long neck water pump on a 454?
Old Apr 21, 2014 | 08:00 AM
Jbster's Avatar
Jbster
Not if you're using Corvette big block pulleys. Has to be a short pump.
To Gear stick knob
