Overheating........kind of
Old Jul 17, 2002 | 10:34 PM
white76's Avatar
white76
Default Overheating........kind of
My first post on the corvette forum! I have been on here reading quite a bit and finally decided to register. What a great resource for corevette owners. Anyway here is my problem......I am not sure what exactly is causing it, but I have a problem with the radiator fluid boiling out into the overflow and proceeding onto the ground. The temps run about 200 degrees, which is warm, but never exceeds that. The antifreeze usually doesn't boil out until the car is stopped and the ignition is turned off. Within a minute you can here the antifreeze pouring onto the ground. Is it something simple like a radiator cap not holding pressure? I do seem to have some build up inside the radiator. Maybe it is plugged and needs to be flushed. Someone set me straight.
Old Jul 17, 2002 | 11:05 PM
82dukman's Avatar
82dukman
Default Re: Overheating........kind of (white76)
Welcome to the forum. First, I would change the thermostadt and put a 160 degree one in. Inexpensive and easy to do. I would bet this is your problem, stuck one on side or the other.
[Modified by 82dukman, 10:06 PM 7/17/2002]
Old Jul 17, 2002 | 11:06 PM
Scott78's Avatar
Scott78
Welcome. Might be the cap, but does the overflow hold fluid at the "hot" mark or is it possibly cracked. Or are you describing the coolant expanding more then the volume of the overflow tank between the cold and hot mark.
I know mine varies about an inch between it's cold level versus it's hot and I run about 205 this time of year highway driving. Another thing to check is the overflow hose itself, make sure it's intact between the radiator and overflow tank. Hope that helps.
Scott
Old Jul 18, 2002 | 12:10 AM
page62's Avatar
page62
When your engine is cold, the fluid should be at the "Cold" mark in the bottle. Anything above that and some of it is going to come out the top of the bottle (been there, done that). :smash:
Old Jul 18, 2002 | 06:12 AM
AZ76's Avatar
AZ76
Welcome fellow 76er...I have no clue on your problem, but thought Id give the ol waving guy :seeya
Jason
Old Jul 18, 2002 | 09:45 AM
stickboy's Avatar
stickboy
Default Re: Overheating........kind of (page62)
Also check for cracks in the tank and tubing
Old Jul 18, 2002 | 12:38 PM
68shark's Avatar
68shark
Default Re: Overheating........kind of (stickboy)
I had this problem couple of summers ago. The cap was ok (replaced to be sure!) but the lip on the aluminum overflow tank had become worn/dinged and was preventing a perfect seal, thus my system wasn't properly pressurized. I fixed it with my usual skill (pair of pliers) and car hasn't puked since!! :cheers:
Old Jul 18, 2002 | 01:03 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Overheating........kind of (68shark)
Glad to have you here with us. I would agree with what has already been said. If the radiator cap is old I suggest replacing it and the thermostat. As you said, flushing the radiator is a good idea also. How is your fan clutch? If it is leaking and throwing oil on the fan, it probably isn't working too well anymore.
Old Jul 18, 2002 | 03:08 PM
BeachinVette's Avatar
BeachinVette
Welcome aboard
I would change the rad cap and thermostat and do a good flush. See what happens.
Good Luck
Bob
Old Jul 18, 2002 | 04:43 PM
terryrudy's Avatar
terryrudy
Welcome!
I had same problem about a month ago after swapping heads. Changed radiator cap, pull thermostat and tested it (fine) and then filled up the block up to the thermostat with water and put it all back together. No problems since. I think part of my problem was the water in the block. Must've had some air pockets.
good luck!
-terry
Old Jul 18, 2002 | 09:35 PM
white76's Avatar
white76
Thanks for the info guys. You have pretty much reinforced what I thought. I think I will start with a new radiator cap. By the way, no thermostat. Is there any harm in not having one? Also, I remember someone on the forum stating that summit offer a griffin aluminu radiator for $185. Is this a misprint? Most of them that I have seen are about $500. I will let you know when I finally figure out what is wrong with the car.
Old Jul 18, 2002 | 10:20 PM
Paul L's Avatar
Paul L
Not to be a little silly in my reply, but did you fill the overflow tank to the top?
Old Jul 18, 2002 | 10:28 PM
FeedVaal's Avatar
FeedVaal
Default Re: Overheating........kind of (paul79)
Jon, I thought that was crazy low for a price too so I checked it out on Summits web site, yep, $185 for an aluminum radiator. I paid $225 for a copper cheapo replacement at O'Reilly's 2 years ago. I was cheesed.
To Overheating........kind of
