79 Corvette problems
Old Apr 6, 2014 | 09:39 AM
rebelee08's Avatar
rebelee08
Default 79 Corvette Brake problems
I have searched for threads and haven't really found much, so I thought I would ask for opinions.
Brakes were fine then all of a sudden they became mushy...you could pump and get a little.
Then when I sent it to have heads rebuilt mechanic said when he drove it it had no brakes. Called and said that brake booster had gone out. Replaced brake booster/master cylinder. After replacing he thought that the left front caliper had gone out. He thought it was pulling to side.
I drove it and it does not feel like its pulling to either side to me. The pedal is still very soft and clear to the floor before it will stop.
I am by no means a mechanic! I think before I go yanking and replacing calipers that it may be an issue of air in the lines from replacing booster and MC? Any suggestions and comments are most appreciated, thank you in advance for your help!
Last edited by rebelee08; Apr 6, 2014 at 10:03 AM. Reason: Changed title forgot to insert "Brake"
Old Apr 6, 2014 | 09:52 AM
Street Rat's Avatar
Street Rat
It sounds like your car needs a thorough brake bleeding. That's the first thing that I would do. Plenty of information and threads here on the subject.
Old Apr 6, 2014 | 11:06 AM
drwet's Avatar
drwet
Most likely problem is air in the brakes. Possibly for the installation of the master cylinder, although I don't understand why the master cylinder was replaced if the problem was the booster. If you don't have stainless steel sleeved calipers on all four corners, you should probably bite the bullet and do that. If you have excessive runout in your brake discs, that will tend to suck air past the seals, and you will never be able to get the brakes bled properly. There is also the possibility the length of the pushrod on the brake booster is not correct. All these issues have been dealt with multiple times on this forum. Do a search and do some reading. Lots to learn.
Old Apr 6, 2014 | 01:02 PM
rebelee08's Avatar
rebelee08
Ok just removed the front wheel and the verdict is probably what he said...blown caliper. I figured that if the caliper was blown that it would have pulled to the right and it did not ughhh
Thanks for the reply, now to price a new left front caliper
Old Apr 6, 2014 | 01:42 PM
7t9l82's Avatar
7t9l82
replace calipers in pairs,
To 79 Corvette problems
