It's good to hear that the insurance company is honoring their contract.....that's one less thing to deal with during the loss of a great car.
Yes it makes it a little easier. I didn't lose money on the car, because I never had to spend much on it. It was always just that nice of car. I however think I should have bumped up the insurance because they seem to have gone up in price a lot over the years at least the truly nice ones. At Back to the 50's and Car Craft Summer Nationals I see quite a few 64 SS cars, not many as nice as mine was. Same for cars for sale. Oh well.
Thanks for everyone's support! I really appreciate it!
I would like to point something out with regard to the fuel line, before anybody starts jumping to any conclusions. OP says the zinc in the carb melted, and steel line did not. Zinc has a relatively low melting point for a commonly used metal, at 787 degrees F, while steel has a melting point of around 2500 degrees F., depending on its particular makeup. The fact that the fuel line is disconnected from the carb does not necessarily mean that is what caused the fire.
I also would like to take this opportunity to say that I'm not an arson investigator, or a metallurgist, or even any kind of forensic expert at all. I'm just a guy who knows that zinc has a low melting point, that's all.
Scott
I am not sure what conclusion you think I was coming to but when something like this happens its terribly unfortunate and if anyone can learn from it and not have a repeat of their own then there is a lot of value in the OP post.
I will say that I found my rear float bowl leaking the other day. Would only happen after this cold winter and only after the engine had been run and then allowed to cool. I kept finding brownish liquid stains on my aluminum intake and at first thought my rear accelerator pump diaphragm was leaking due to the location. Instead it turned out to be the all 8 bolts (4 in each float bowl) were loose from the cold weather and metering block gasket shrink.
I tightened up the float bowls and the leak stopped. So maybe someone can learn from what I just ran into. Not saying that is what happened here but I sure was surprised and then when I read this post it reminded me to check my fuel lines and fittings. These cars tend to sit more than regular drivers so odd stuff happens to them.
I read where 10% of each model year is lost each year due to fire, like yours, theft, accident, sinkholes, etc. Now all the other '64 2 door Impalas are worth more. So yours did not go up in flames in vain.
You'll need paint, hoodliner, windshield, carb, and pretty much everything non-metallic under the hood, but that car is far from a write off imho.
The car looks a lot worse in person! Gas had leaked under it all the way to about 3 foot behind the car before it lit off. The rubber body mounts were dripping on the driveway, so it's a full body off resto. The whole front clip is warped from the heat. There's nothing under the hood that isn't really burned up. The gas fire led to an electrical fire, so it needs a harness. The electrical fire was burning under the dash. The gauge panel is ruined, so a new set of gauges. It had 72,000 actual miles, but since the speedo is shot, that is gone too. The smell of burned car will never leave the carpet, headliner, and seat foam. Trying to replace the foam covered with the original vinyl would lead to cracked seat covers. It would be a huge job I'm not wanting to take on at this point in my life. I haven't even finished my 75 Vert yet. It would also be very expensive. Someone will buy it from the insurance company and fix it up.
It doesn't matter now anyway. The insurance company had it picked up and they are sending me a check. I mailed them the title.
Again, thanks for everyone's support!
Yikes, OK with that info I'd tend to agree it's a write off. I was thinking it was mostly just an engine bay fire. But once you've melted off suspension components, the entire wiring harness, and the interior ... yeah, you're pretty much just dealing with a shell. Sorry to hear it, buddy. Good to know the insurance isn't jacking you around.
that is definitely salvageable, just too much work for me, but you know someone will buy it and either restore it, or use all the rest of the parts they can on another resto...still, sad for you!!
My price and joy '73 camaro burned up in a garage fire when I was 16. It wasn't worth much though. But my Wife's Dad had a canary yellow '66 vette back in the 80's in mint shape. He took the fuel line or carburetor off or something and went to the parts store (story I am told), when he was gone, her mom went out turned the key to start it and after 30 seconds, kaboom! burned down to nothing....I never saw it burned but saw pics before and it was nice. Too bad he didn't have insurance on it (not sure why, just what I was told) Glad you had insurance on yours and is a good reason for people to keep fire/theft on their car over the winter when not driving it. That's what I do, take everything off but fire/theft until the Spring...
V2 - before you administer the last rites here, I don't see much from your picture that isn't repairable or replaceable. I know how much it pains you to see your baby coated in soot like she is, but it looks like paint, upholstery, wiring harness, new belts and hoses, maybe, MAYbe a motor rebuild and yes, definitely a NEW CARBURETOR to bring her back to her former majesty. I can understand how your heart is broken, but as an objective outsider, I see a very rebuildable core. Don't throw dirt in her face just yet. Good luck with the adjuster!
Update: Just read your latest post, and yeah, if there was that much heat warpage, you may have made the right decision. Still, my condolences.
