Marking rear gears
Old Apr 6, 2014 | 10:08 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Default Marking rear gears
I picked up a rebuilt rear end from another forum member. It looks to be in great shape but I wanted to check the runout and pattern before installing it. I put marking paste on the ring gear but can't seem to get a visible pattern on the gear. Either the pinion gear is missing ( unlikely ) or I'm doing it wrong.
It occurs to me that I should have something against the ring gear to put some pressure on it to allow the pinion ger to produce an imprint.
Ideas? Obviously, I've never done this before.
Old Apr 6, 2014 | 10:57 PM
TOM B1's Avatar
TOM B1
Mark the gears on the leading edge; the way it turns when moving forward; then turn the pinion the same way and you will see the pattern.
Old Apr 6, 2014 | 11:23 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
The Idea is to put drag on the ring gear simulating a load.
Old Apr 6, 2014 | 11:47 PM
TimAT's Avatar
TimAT
No load= no pattern. I use a handful of shop rags and just add all the drag on the ring gear I can.
Old Apr 7, 2014 | 06:06 AM
Gordonm's Avatar
Gordonm
I put a heavy leather glove on and keep pressure on the ring gear with my hand in the glove. Just put a drag on it as you turn the pinion. I actually use a battery powered drill to turn the pinion so you get it to rotate a number of times while keeping pressure on the ring gear.
To Marking rear gears
