Carburetor leakage!
Jul 18, 2002 | 08:35 AM
Carburetor leakage!
I changed my spark plugs last night (what a pain that was!) and noticed a very strong smell of gas, I checked my carb and saw little puddles of gas on my manifold. It wasn't coming from the gas line, that was on secure. I looked at the gasket and it looked like it was coming from there, can gas leak from the gasket, do I need a new one (I don't know much about carb's)?
Jul 18, 2002 | 10:03 AM
Re: Carburetor leakage! (mpro72vette)
either the plugs on your carb went bye bye.... :seeya :seeya
or the diaphragm in your fuel pump went bye bye..
either way, something went bye bye..
Jul 18, 2002 | 10:08 AM
Sounds to me like your about to start learning about carbs! :cheers:
Jul 18, 2002 | 10:13 AM
Re: Carburetor leakage! (page62)
:lol: :lol: Yep, I guess its going to be the first thing I learn!
Jul 18, 2002 | 10:15 AM
Re: Carburetor leakage! (daily_driver)
Hmm it might be easier to say "HI" to a new carb!! :confused:
if its your plugs, then break out the epoxy......
take the carb off...
yank the throttle plate thingie off the bottom..
and epoxy up all the bowl plugs...
put on new gaskets..
and yer good ta go.
[Modified by daily_driver, 9:16 AM 7/18/2002]
Jul 18, 2002 | 10:30 AM
is there a special epoxy I would use? Can I bye it at an auto part store? Thanks for the info!!! Can't wait to dive into this one! :D
Jul 18, 2002 | 10:42 AM
a cheap 5 oz thing of epoxy will do..
i buy mine from a marine store....
make sure its good with fuels and metal and .......
some people use JBweld also..
Jul 18, 2002 | 10:50 AM
heres a pic to help you see where they are.. did this a while ago....
you have to remove the bottom throttle plate....its easy enough, just a few long screws....
there is an additional plug not circled in the picture i think.... i forget how many plugs there are on a quadrajet...
[Modified by daily_driver, 9:52 AM 7/18/2002]
Jul 18, 2002 | 10:58 AM
Thanks, this is a big help! When I get home I will take the carb off and take a look. If this is the problem it will be a lot cheaper! :cheers:
Jul 18, 2002 | 11:03 AM
i have more pictures of the entire process that i took a while ago..
ill email em to you
one of these days ill put em into a FAQ and submit it to corvettefaq.com
Jul 18, 2002 | 11:07 AM
ill email em to you
:cool: :cool: Thanks!
Jul 18, 2002 | 11:15 AM
Don't get a new carb. Check the gaskets on the bolts for the fuel bowels, thoses go bad easey. Check the mettering block and fuel bowel gaskets too and you migt also need a new accelerator pump diaphram. It is all very easy to fix, only 4 bolts to get off the bowels and only 4 screws for the diaphram. Sray some carb cleaner/throtle body cleaner on it and wipe it good. Then if you start the car agin you could see where it is coming from. PS... don't blow your self up :chevy
Jul 18, 2002 | 11:30 AM
I believe the 72 LT1 had a Holley.
Ed
Jul 18, 2002 | 11:31 AM
Re: Carburetor leakage! (Cory1970)
Thanks Cpry1970, I will add this to my list too, all the more ammo to tackle this problem! :cheers:
Jul 18, 2002 | 11:33 AM
Re: Carburetor leakage! (ED DINAPOLI)
Ed
Ed, yes this is true, I already check it, says holly on the front and back.
Jul 18, 2002 | 11:39 AM
St. Jude Donor '09
It's most likely the fuel bowl gaskets on a Holley but could be accelerator pump diaphragm or .......time for a kit :cheers:
Jul 18, 2002 | 11:45 AM
Re: Carburetor leakage! (yellow 72)
How much does a kit go for? Is it hard to install? I'm a beginner. Thanks to everyone, I have a lot of things Ican look at now!
Jul 18, 2002 | 12:11 PM
Cruise-In IV Veteran
Cruise-In V Veteran
Holley rebuild kits are cheap and easy to install. $20 or $30, you will also want a gallon of carb cleaner so you can soak it. We can walk you through this one pretty easy. In fact, you can probably figure this out easily yourself.
