Engine update!
Old Jul 18, 2002 | 09:00 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Engine update!
It seems that the rings on my engine have finally seated a little better (at least it looks like). The smoking stopped and I'm consuming less oil. I have still some oil consumption but it's much less. I also get rid of the dieseling problem. The only thing I did was to set the idle lower. I'm idling now at 850 - 1000 RPM. The idle used to be between 1100 - 1250 RPM which caused some dieseling...
:cheers:
Olivier
[Modified by GrandSportC3, 8:00 AM 7/18/2002]
Old Jul 18, 2002 | 09:20 AM
Alwyn678's Avatar
Alwyn678
Default Re: Engine update! (GrandSportC3)
Congrats................. :cheers:
Old Jul 18, 2002 | 09:31 AM
GrandSportC3
Default Re: Engine update! (Alwyn678)
Thanks! I will put the car again on the dyno as soon as I get my distributor re-curved and my carb swapped to a mechanical secondaries carb.
:cheers:
Olivier
Old Jul 18, 2002 | 10:51 AM
QuickVet's Avatar
QuickVet
cool. let us know how it goes.
Old Jul 18, 2002 | 11:17 AM
GrandSportC3
Default Re: Engine update! (QuickVet)
I will! I might even go to Dyno Day in Orlando this Saturday but I'm not sure... I think it might be better swapping the carb fist and then dyno...
:cheers:
Olivier
To Engine update!
