Replacement Fuel Pump Issue
Old Apr 10, 2014 | 10:51 PM
wheatpj's Avatar
wheatpj
Default Replacement Fuel Pump Issue
I ordered a 70-74 454 replacement fuel Pump from one of the Corvette vendors. I should be able to move the pump arm by hand, right? It like it's jammed.
Old Apr 11, 2014 | 12:33 AM
Ironcross's Avatar
Ironcross
If it don't work in your hand, don't expect it to work on the engine....Go to your local parts store and buy one....send the other back
Old Apr 11, 2014 | 03:46 AM
jyounane's Avatar
jyounane
It's a very stiff spring on the pump actuator. Make sure you're trying hard enough. It will work by hand.
Joe
Old Apr 11, 2014 | 11:12 PM
wheatpj's Avatar
wheatpj
Joe
I'm pushing really hard...won't move. It must be jammed.
Old Apr 11, 2014 | 11:30 PM
scottyp99's Avatar
scottyp99
Ya gotta push really, really hard.
Scott
Old Apr 12, 2014 | 12:03 AM
72hawk454's Avatar
72hawk454
agreed. If this is the first time you've moved a pump lever I recommend you push so hard you think you will break the arm. Then it will move. If the arm breaks...it was truly a bad pump.
By the way, did the pump look USA made or was it stamped made from some foreign company? I use the same pump and was going to put a new replacement on mine while the engine is out of the car. I'd really look to put a high quality, but original-type pump that is made in the USA. If you decide this is bad pump, please shoot me a private message with some details so I can avoid the same vendor part. thanks.
Old Apr 12, 2014 | 01:01 AM
wheatpj's Avatar
wheatpj
I got it to move...hurts my hand. That is a really stiff action. I assume it will move more easily over time. The stamping on the pump sources to a AirTex brand pump Part #40770. I'm a little disenchanted because I found the same pump on the O'Reilly Auto Part website for about half what the Vendor charged me.
Old Apr 12, 2014 | 08:48 AM
Jeff_Keryk's Avatar
Jeff_Keryk
I think I paid $35 for a 68 L36 pump... Not the AC Delco, it was Master 40659. Made in USA.
Old Apr 12, 2014 | 10:29 AM
72hawk454's Avatar
72hawk454
thanks. BTW, the effort it took you to push the lever is normal. That big motor will have zero trouble.
Old Apr 12, 2014 | 10:41 AM
Red 69's Avatar
Red 69
I assume you held your fuel pump with both hands and pushed the pump lever against a solid wood structure. They are all stiff, the spring needs to be stiff to return against the cam lobe at high RPM.
Note: the vendor pump likely has a return nipple for unused fuel to return to the fuel tank. This is to keep the fuel entering the carb as cool as possible. Hot fuel is more likely to cause vapor lock, and you don't need that. Compare the vendor pump with the local parts supplier pump and see if they both have the return line nipple. For a pump without this feature, you can buy a regulator with the fuel return, but that will cost around $50. Just something to consider. GM provided a return line because a tight engine bay can get hot in slow traffic, with vapor lock a possible result.
Old Apr 12, 2014 | 11:40 PM
wheatpj's Avatar
wheatpj
I had it in my lap and pushed down with both hands. Tomorrow I install the pump. Hope all goes smoothly.
Thanks everyone
Old Apr 15, 2014 | 09:50 PM
Ironcross's Avatar
Ironcross
Airtex pumps and products are top of the line parts carried by most auto parts stores....Too bad about the over charge, I would recommend sending it back and therefore sending a message that high prices don't fly ...especially on the same identical part
Old Apr 19, 2014 | 08:43 PM
wheatpj's Avatar
wheatpj
Good to hear the pump is top quality. The price (for replacement pumps) was pretty much the same from the other Corvette vendors too. I guess that's the premium we pay for driving Corvettes. Heck, the HVAC repairman sees my Corvette is the garage and starts trying to sell me a new furnace...top of the line furnace.
Old Apr 19, 2014 | 09:43 PM
68Thunder427's Avatar
68Thunder427
I buy almost all of my stuff from ORielly's or Napa and they carry good quality products. I would send that one back if you can and save the money. Check the local parts houses first because some of the "online" sites gouge you just because.
To Replacement Fuel Pump Issue
