Tachometer Not Working!! The Agony!!
Old Apr 11, 2014 | 11:07 PM
corvettejet's Avatar
corvettejet
6th Gear
Default Tachometer Not Working!! The Agony!!
So I am new to the forums, but have been an avid watcher/viewer/listener?? since I bought my corvette 4 months ago.
The tachometer didn't work when I bought it, and the previous owner said I needed to replace the Tach filter. After doing so, still nothing. The needle sits well below 0rpm and nothing moves it. Before I go into the dash is there anything else that could be the problem? I also have a voltmeter if that can help with diagnosis.
Old Apr 11, 2014 | 11:39 PM
TX-Techman's Avatar
TX-Techman
Default What year
Well you didn't give us much to go on, I assume since you said "filter" it is an electronic and not tach driven, but need more info.
Year
engine and basic info
is it original or a modified setup
for starters
Old Apr 12, 2014 | 06:55 AM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
Click here - some good info
Old Apr 12, 2014 | 09:10 AM
corvettejet
6th Gear
It is a 79 with an L82, everything is stock. It must be a wiring issue as the tachometer doesn't move at all, regardless of ignition on/off.
Old May 21, 2014 | 08:49 PM
Redboat's Avatar
Redboat
I've got a 76 , doing the same thing . Did you get it fixed ? If so , what did you find was wrong ?
Redboat
Old May 22, 2014 | 03:22 PM
dochorsepower's Avatar
dochorsepower
Many, many years ago the same happened to my '75. I removed the tach, looked at the circuit board and found a burned out resistor. I soldered in a new one and it's been fine for the last 25 years. Take a look.
Old May 22, 2014 | 09:16 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Corvettejet..
In almost all cases the issue is the board. I would bypass the filter for testing.. See if the tach works.
Then I would pulll the tach connector from the back of the tach and test it for power and ground. I would then test continuity from the dash connection to the connector the filter plugs into. If you have continuity then your issue is more than likely the tach board or the movement.
The other day I got to thinking, there is a way to find out if the board (or movement) is dead...
If you have the tach in your hand and apply 12 volts and ground to it..
You then use a jumper wire and attach it to the signal terminal... quickly tap the other end of the jumper to the 12 volts terminal with power and the tach should show upward movement.. If you get no movement, you should consider replacing the board.
75-77
78-82
Corvette Tachometer Board Installation Instructions 1978-1982
http://willcoxcorvette.com/repairand...lp.php?hID=252
Corvette Tachometer Testing, Removal, Board Installation, Video Link 1978-1982
http://willcoxcorvette.com/repairand...lp.php?hID=290
For the 75-77 tach's..
Corvette Left Hand Dash Pad Removal Made Easy 1968-1977
1978-1982
1975-1977
Thank You,
Willcox Inc.
Old May 22, 2014 | 10:08 PM
Redboat's Avatar
Redboat
Originally Posted by Willcox Corvette
Corvettejet..
75-77
78-82
1978-1982
1975-1977
Thank You,
Willcox Inc.
Thanks for the info , just tried bypassing the filter , still doesn't work . Tach needle sits at 0 till I turn the key on , them the needle moves backwards an inch or so when engine starts .
Redboat
Old May 23, 2014 | 06:46 AM
Super6's Avatar
Super6
Redboat
I freely admit to knowing absolutely nothing about a non-mechanical tach, so don't shoot me. If the needle moves the wrong way, is it possible that 2 leads are reversed?
Old May 23, 2014 | 06:52 AM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Sounds like the board. Troubleshoot per Willcox instructions and life will be good again.
Old May 23, 2014 | 09:30 AM
0Willcox Corvette
Former Vendor
If the needle moves backwards this usually means only one side of the board is working.
You might try loosing up the nuts on the back of the back and then re-tighten them. If the tach needl still moves backwards then you do need a board.
Willcox
Old May 31, 2014 | 09:51 AM
sd77's Avatar
sd77
5th Gear
Willcox
Hey Wilcox
First time posting, sorry if you've covered it already somewhere on the forum but i can't seem to find a link with the same problem I'm having, i have a 77 that i just bought and the tach doesn't work below 2800 but seems to work above 2800. The engine was replaced with a crate engine at some point. Just wondering where to start? Also when i shut the car off it pegs the needle far right if that helps.
I did try hooking the wire that goes to the filter directly to the distributer the tach pegs to the right.
Thank you
To Tachometer Not Working!! The Agony!!
