Installed control arm bushings without grease...
Old Apr 12, 2014 | 03:08 PM
fta1995's Avatar
fta1995
3rd Gear
Default Installed control arm bushings without grease...
If patience is a virtue, I must not be very virtuous. I was excited after finally getting the bushings out of the a-arms and starting reassembly...and assembled the new bushings (rubber, if that matters) without putting grease on the cross shaft or bushings.
Any advice on where I can go next? Did I earn the privelege of getting to remove the new ones?
Thanks,
Martin
Old Apr 12, 2014 | 03:29 PM
TimAT's Avatar
TimAT
There was no provision on the original rubber bushings for grease. The sleeves "lock-in" place when the bolts are tight because of the serrated ends, and the outer shells are pressed into the arms. No lube needed. Maybe some rubber dressing is you want them to look pretty, but that's it.
Old Apr 12, 2014 | 07:21 PM
kanvasman's Avatar
kanvasman
Make sure that the car is on the ground, so that the weight positions everything correctly before you tighten up the outer shells.
Old Apr 12, 2014 | 08:05 PM
gcusmano74's Avatar
gcusmano74
I agree.
Push the car back and forth a few times so that you are sure the suspension is "settled" first.
To Installed control arm bushings without grease...
