Fan clutch problem?
Old Apr 13, 2014 | 08:10 PM
gcusmano74's Avatar
gcusmano74
Default Fan clutch problem?
'74 smallblock w/AC.
Put in a lightweight steel fan (Flex-a-Lite) to address a clearance issue with a spreader bar.
Now it seems as if the clutch never really disengages. I can hear the fan turning all the time. When I shut off the engine, the fan stops turning almost immediately; it never seems to "freewheel".
I always thought that the failure mode of a fan clutch is to freewheel all the time, not stay locked up.
Can the fan be too light?
Old Apr 13, 2014 | 09:21 PM
REELAV8R's Avatar
REELAV8R
You got two different systems combined. The flex a lite fan is designed to allow the blades to flatten out at higher rpms to reduce the drag of a straight driven fan.
The clutch for a clutch fan is designed to allow the fan to not turn the same speed as the engine when it's not needed reducing the drag on the engine due to it' aerodynamic resistance.
So the clutch is designed to turn a fan that presents more resistance to turning than the flex fan is going to give it. I would expect it to turn that flex fan at a higher speed all the time than your stock fan.
If it doesn't overheat and the noise doesn't bug you too much I can't see It causing a problem.
Old Apr 14, 2014 | 08:50 PM
gcusmano74's Avatar
gcusmano74
Flex a lite also makes a replacement rigid steel fan that bolts on to the fan clutch, and theoretically operates the same way as a stock fan. It is somewhat lighter than the factory fan. That's what I installed.
Old Apr 15, 2014 | 10:19 AM
C376FL's Avatar
C376FL
I have a question after reading your thread about clutch fan. If it is designed to turn the fan slower than engine speed, would it to cause the engine to over heat sitting at a red light with a/c on. My '76 does not have one at this time, do I need one?
Larry
Old Apr 15, 2014 | 10:27 AM
MelWff's Avatar
MelWff
If you installed a light weight fan it has less mass and does not have sufficient weight to continue to freewheel once the engine is turned off. It will also spin faster than a heavier fan when the engine is running.
A 76 with A/C should have a clutch fan.
Old Apr 15, 2014 | 05:49 PM
C376FL's Avatar
C376FL
Hi! welWff
I guess I will need to add that to the list.
Larry
Old Apr 15, 2014 | 07:18 PM
REELAV8R's Avatar
REELAV8R
Larry
At idle when it's hot it will be fully locked and turning with the engine. When it's cooler it will turn slower than the engine speed due to not being fully locked up.
At higher rpms the fan will stay with the engine rpm until it either cools down a bit and the clutch allows it to slip or the rpm of the engine increases enough that the drag on the fan is increased enough to cause the fan to turn slower than the engine due to the clutch.
Old Apr 15, 2014 | 09:39 PM
gcusmano74's Avatar
gcusmano74
Larry
The fan clutch allows the fan to freewheel until the underhood temp reaches some predetermined high value, at which point it locks up and drives the fan at almost engine speed. With the stock fan and clutch, the fan on my car never locked up unless it was a very hot day with the AC on.
To Fan clutch problem?
