Block # help???
Old Jul 18, 2002 | 07:18 PM
racinhound's Avatar
racinhound
Default Block # help???
Can anyone point me in a direction here? On a 79 L82 non-matching how can you determine if it is a L82 block? The #'s on the frt below the head are V0206TYX,50137. Casting # on the drivers side rear is 897000. Is this an L82 transplant or just a plain Jane 350?
Old Jul 18, 2002 | 07:25 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Re: Block # help??? (racinhound)
I didn't find any such casting number. Are you sure that the first number is a 8 and not a 3?? There are following casting numbers that could look similar:
3970010
3970020
I think that you have a 3970010 which could be either a 2 or a 4-bolt block. My 383 stroker is built on a 3970010 block and it's a 4-bolt
:cheers:
Olivier
[Modified by GrandSportC3, 6:28 PM 7/18/2002]
Old Jul 18, 2002 | 08:05 PM
racinhound's Avatar
racinhound
Default Re: Block # help??? (GrandSportC3)
You are correct it is 3970010. Is there anything that the #'s on the frt of the block tells you? I guess my question is anyway to to determine 2 or 4 bolt from those #'s?
Old Jul 18, 2002 | 08:09 PM
Chris@VetteFinders's Avatar
Chris@VetteFinders
Platinum Supporting Dealership
I don't think any 79 engines are 4 bolt mains
Old Jul 18, 2002 | 08:20 PM
GrandSportC3
no - the only way to find out is to either take of the oil pan and check it or to drain the oil and use a bore-scope to look inside to see if it's a 4-bolt block. 3970010 is one of the most common casting numbers...
:cheers:
Olivier
Old Jul 18, 2002 | 08:28 PM
racinhound's Avatar
racinhound
Default Found this on the casting #
"3970010....302.....69....4...Z-28 Camaro
3970010....327.....69....2...Trucks and industrial
3970010....350...69-80...2 or 4"
Does anyone know of a way to break down the V0206TYX
I believe the V=Flint Plant 0206=Feb 6 TYX=?????
Anyone????
Old Jul 18, 2002 | 09:30 PM
racinhound's Avatar
racinhound
Default For those of you interested
http://www.nastyz28.com/spmenu.html
This list all the suffixes found on the right frt pad under the head and the use of the motor originally. Which in this case is from a 1975 1/2 or 3/4 ton pickup :nonod:
Old Jul 18, 2002 | 10:17 PM
VETDRMS's Avatar
VETDRMS
here's a neat trick:
Actually you CAN tell if a block is a 4 or 2 bolt, just by opening your hood.
Look at the pad where the waterpump connects to the block on the
passenger side. If it is a narrow pad that sticks out a little over an inch,
its is a 2 bolt. If it is a wide pad that sticks out about 1/2 inch, it is a
4 bolt. No kidding. :smash: :smash: :cheers: :cool:
Old Jul 18, 2002 | 10:28 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
TYX,1975 truck 350 ci with 4 barrel and all trucks with a 4 barrel have 4 bolt mains as far as i know. :chevy
Old Jul 19, 2002 | 01:51 AM
Tom73's Avatar
Tom73
Default Re: Block # help??? (clem zahrobsky)
I agree. It the suffix starts with a "T" then it is 99.9% likely it is a truck engine.
tom...
Old Jul 19, 2002 | 03:31 PM
Tomi72's Avatar
Tomi72
Default Re: Block # help??? (VETDRMS)
I have two bare blocks in my garage and they are the exact opposite to the above :rolleyes: I don't think 2 and 4 bolt can be identified without dropping the pan.
rgds Tomi
To Block # help???
