Holley carb idle problem
Old Apr 20, 2014 | 05:03 PM
rep69's Avatar
rep69
Default Holley carb idle problem
Today I took the car on its first long drive since the engine was overhauled. My 1969 427 390 hp has been running good since the overhaul. I have put around 100 miles on the engine. The problem i notice is that when I have the air conditioning on and stop at the stop light the engine will not idle and then it floods out and dies. I have to hold the gas pedal to the floor and crank the engine to get it to start. Maybe a simple adjustment of the floats? a/c compressor belt too tight? The holley 4150 double pumper was rebuilt last year and was operating good before the engine overhaul.
Old Apr 21, 2014 | 10:50 AM
MelWff's Avatar
MelWff
Automatic or manual transmission? What is the idle speed with A/C off and what is it with A/C on? Assuming the idle is correctly set, remove the front sight plug with the engine idling and observse the float level, it should be just even with the bottom of the hole. Adjust if necessary. Then do the same with the rear.
Old Apr 21, 2014 | 08:30 PM
Tom454's Avatar
Tom454
I don't know if this app is supposed to have a idle solenoid due to the A/C (no time right now to look it up)... but if so, check to see that it's present & working when the A/C is on.
To Holley carb idle problem
