Oil Pan Gasket Problem
Old Apr 20, 2014 | 09:04 PM
Jartanyon's Avatar
Jartanyon
Default One-Piece Oil Pan Gasket Problem
Bought a Moroso 1 piece oil pan gasket and can't get it compressed enough to get any of the bolts in. If i push it down on one side, the other side pops up too high. Do you normally have to get longer bolts when using these gaskets?
http://www.summitracing.com/parts/mor-93150
Old Apr 20, 2014 | 09:31 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
I've seen some one piece gasket "kits" that come with longer bolts.
One of the reasons I stayed with old style gaskets.
Also from Summit......
http://www.summitracing.com/parts/fe...510t/overview/
Old Apr 20, 2014 | 09:36 PM
Dan H.'s Avatar
Dan H.
St. Jude Donor '17
There are two different thicknesses for the portion of the seal that runs between the oil pan and timing chain cover. I had leaks because i needed the thicker gasket and had the thinner one. You could potentially have the opposite situation happening. My experience was with fel-pros
Old Apr 21, 2014 | 12:36 AM
cagotzmann's Avatar
cagotzmann
Used the same gasket and replaced all bolts with long ones. 78 L48 engine.
Old Apr 21, 2014 | 09:26 AM
Jartanyon's Avatar
Jartanyon
Thanks guys - the pan I have requires the thicker gasket. The only thing is, I feel like there is too much gasket material on both ends that will prevent the sides from making a good seal. I wish the Moroso came with new bolts like the Fel-Pro - both are the same price now at Summit.
cagotzmann - do you remember what size bolts you used?
Old Apr 21, 2014 | 05:45 PM
tektrans's Avatar
tektrans
But a stud kit from summit.
Old Apr 21, 2014 | 05:56 PM
cagotzmann's Avatar
cagotzmann
I dont remember the size but there are 2 sizes. The end units at the crank and balancer. Total 4 bolts, and the remaining bolts. I just took both types and bought some grade 8 that where 1/4" longer. also purchased some locking washers.
To Oil Pan Gasket Problem
