What cam is this cam?
Old Apr 21, 2014 | 07:04 AM
c3_dk's Avatar
c3_dk
Default What cam is this cam?
From a SBC.
Text on the cam:
Z010
CWC
E5
C4
EP1
/John
Old Apr 21, 2014 | 09:50 AM
wilcar's Avatar
wilcar
What block did it come out of?? Did the numbers and letters come from areas between the lobes?? Anything on the rear end face of the cam?? A lot of after market cams have some sort of letters or numbers on the rear face. Your marks sound like cam core markings. Do you know if the cam is a hydraulic or solid lifter cam? Any history on it?? Did it come out of a running engine or did you just get it from someone at a swap meet??
Old Apr 21, 2014 | 10:50 AM
c3_dk's Avatar
c3_dk
I have no more info on the cam.
The numbers between the lobes is, D4, 09, C4, E5, EP1 and CWC
And stamped in the end is Z010
Old Apr 21, 2014 | 01:23 PM
StraubTech's Avatar
StraubTech
Engine Power Core
Z010 cam from them I can look the specs up.
Old Apr 21, 2014 | 04:34 PM
wilcar's Avatar
wilcar
I saw on the offshore only website that the z010 cam came out of a gen 4 big block chevy 454 that a guy had but know one knows the specs. Whether or not yours is a big block cam is anyone's guess. I once had a melling pontiac ram air 3 cam I bought but code that was stamped on the end indicated it was a big block chevy cam. Sent it back to melling and it ended up being the correct pontiac cam but just got stamped wrong !!!
Old Apr 22, 2014 | 08:39 AM
c3_dk's Avatar
c3_dk
I cam out of a 350SBC, I took it out my self.
It will go to the bin, I don't want to have a cam in the engine, that I don't know what is it.
Old Apr 22, 2014 | 08:43 AM
StraubTech's Avatar
StraubTech
The lobes can be put on many different cam cores. Wolvorine ground the same lobes on many different engines.
To What cam is this cam?
