Race fuel and timing question
I have a new to me 71 LS5 4 speed. Engine was rebuilt by previous owner. The guy I got it from traded for it and sold it to me. I am trying to find out who rebuilt the engine and what exactly is in it. That is the biggest unknown. I have no idea where timing is set right now. Thats the other big unknown. That one I can probably figure out.
You can hear it run when the guy I bought it from loaded it on the rollback. Hopefully gives you and idea of the cam, etc in the engine.
When I bought the car it was running race fuel. Had that sweet smell. Guy I bought it from told me it didn't need to run race fuel but that the previous owner liked the smell, etc when he rolled into car shows.
I have since run the race fuel out of it and am probably on the first full tank of super unleaded from the local gas station.
I thought I heard the engine clatter tonight while running. Also, it has developed a nasty off idle stumble.
I would rather not have to run race fuel in it if I can keep from it. Is it possible to adjust the timing for it to run better on 93 octane fuel? Or do I just need to bite the bullet and get some race fuel? If you think adjusting timing will work, can you give me some initial idea of where to start?
How about octane boosters? Do they really boost the octane? Would that work in the short term until I can find some race fuel?
I know there are a lot of unknowns here, and I apologize in advance for that. Just looking for what direction I need to go with this.
Doug
Even if you drive around on pump gas with high compression and advanced timing it really shouldnt give you a problem unless you are romping on it.
That car sounds friggin NICE!!!!!! Sounds like there may be a bit of compression in it. You need to ask the PO.
Run a compression test on a couple cylinders. 200 psi cranking compression is about as much as you can tolerate without having to run plus octane fuel, and timing will be critical. Would be nice to know a little more about what's inside that raspy engine.
My SB runs fine on 91 octane@ 200 psi but you have to pay attention to the timing. It also has aluminum heads.
I will see if I can run a compression test on a couple of cylinders.
Just need to try and get rid of the off idle stumble for now and make sure I am not hurting anything with the lower octane fuel.
Thanks for the answers so far. I really appreciate it.
Doug
Doug
One question- did it just start stumbling off idle after you ran out of race gas?
I will get a light on it tomorrow and find a compression tester and check that too. It's a little loud to fire up tonight... neighbors and all....
What should I be seeing as far as timing goes?
Doug
The stumble started today. It had a full tank of race gas in it when I picked it up. I haven't let it get lower than a half tank before filling each time. I have filled it maybe twice from half. I keep smelling the race gas... until today. Took it out for a drive earlier with my son and noticed the clattering and the stumble started. Throttle response was instant before. Today, when I would hit the gas leaving a stop light it would act like it was going to die just before picking up. It has an Edlebrock carb on it. Looks like a Quadrajet but has an Edlebrock tag on it. Not that that makes any difference.
Doug
Until we see what he has, it's pretty much stabbing in the dark, but I know I ended up about 18 initial, 34 vac/centrifugal and 48 total to keep mine happy on 91 octane. Anything past 48 on the total would make the thing trailer hitch.
Compression test shows 120.
Timing:
1000rpm 18
1700rpm 30
2000rpm 40
2500rpm 42
Ran it to 3000 and it was still at 42 degrees.
Didn't seem to want to start this morning. Usually it's couple of pumps of the gas pedal and it fires right up. This morning I had to crank it quite a bit. Not sure of that has anything to do with all of this. Also, the stumble off idle is still there. Pulled a plug wire to do the compression yes and the boot and wire came off... but not the clamp on the plug. I guess I am running down to pick up some new wires today too.
Not sure if it makes a difference but figured you ought to know.... it is running an MSD distributor and MSD 6A box.
I don't necessarily need a tire burning performer. I just want it to run good and solid. I would give up some performance for a good running car, if I have to.
Talked to the guy I got the car from. He knows the guy who built the engine for the PO. Hopefully I will have a phone number and get a call in to him later today.
Again, thanks for the help folks.
Doug
As soon as I get some new plug wires I'll check that too.
Doug
