'78 dash lights
If only the speedo and tach housing or the center bezel are out.. I would go to the printed circuit on the back of the non working unit and check the connector for the printed circuit as well as the printed circuit. On the center gauge bezel.. the top finger on the left hand side is the power for the lamps.
Here is the speedo tach pcb.. it's labeled.
You say the fuse is good... if this is the case, test for power on the left hand side of the fuse with the headlamp switch pulled in the on position. If you have power on the left side, then pull the fuse and check for corrosion in the terminals.
If you don't have power there then I would pull the headlamp switch and test there (if both are out)
I would pull the speedo tach housing.. instructions can be found here: http://willcoxcorvette.com/repairand...lp.php?hID=146.
The gray wires that power up the dash lamps originates at the headlamp switch. The power goes from he headlamp switch to the fuse panel and then to the dash lamps both speedo and tach housing as well as the center gauge cluster and heater control lamp in the top of the cluster. So it is possible your switch may be the problem.
More times than not, it's the fingers on the back of the cluster...
Then headlamp switch.
Then wiring.
If you have an issue with the wiring.. you can do a continuity test from the gray terminal on the pcb to the right hand terminal on by the fuse.
Hope this helps you
Willcox
While the courtesy lamps are not working, there are so many other things that could cause this. I would check them when you have the switch out as well. The headlamp switch doesn't power up the courtesy lamps, it grounds them. When you turn the rheostat to the left, there is a grounding leg on the front barrel of the switch that grounds out. When you do this the lamps come on.
You can see the barrel with the grounding tab in this picture in the lower right.
The courtesy lamps are the orange wire circuit... (same as the lighter, and your compartment lamp) So you telling me the glove box lamp is working tells me there is not a power sortage.. go to the sockets and see if you have power. All the courtesy lamps work by something grounding them. They are hot all the time waiting from ground. (door jamb switch, headlamp switch and so on).
Making sure corrosion isn't present at the fuse terminals.. is very important, we see this in C3 cars more and more as they age (and leak).
Some of my trace schematics are on the website in the tech picture section or in the help and repair files.
Oldguard.. You get ready to dig into this and if I get some spare time... I'm going to help you figure this out.
Willcox
Funny I just noticed something missing from this factory schematic.. The delay timer. I've pasted that one below the first one.
Now I have to bail on you guys.. I'm getting the stink eye from my wife... family time is here.
You are correct about the courtesy lamps.. the switches make the ground when open. So you should have power at the bulb at all times.
Take care and have a great weekend. I'll check back tomorrow.
Willcox
I'll be content that they work but the stock lights are "dim" The brightness was probably good for the 70s but are dim for today's standards.
Also, don't forget about the courtesy lamp timer.....it'll keep the lights on for a bit and if you freak out because the lights are staying on and reopen the door before the timer ends, well, you get the picture.
(that was me before I started researching the electrical circuits on the forum and my AIM for my 77...freaked out because I didn't know there was a timer)
Make sure the wires are not grounded and see if the lights stay on... it's a simple way to take the switches out of the picture.
Turbos time is a nightmare too... located behind the middle of the left dash. Yours.. if we need to go there is behind the glove box liner on the passenger side in most cases.
