Dag Nabbed Trailing Arm Shims.
Old Apr 26, 2014 | 04:43 PM
yelo80vette's Avatar
yelo80vette
Default Dag Nabbed Trailing Arm Shims.
The trailing arm shims need replaced in my 1980. I bought the shims a few years back but just haven't gotten around to replacing them yet. Any time I've looked for advice for installing new ones all I've ever found is everyone saying to "Just measure the width as it is and replace them to the same measurements". My problem is that the old shims have rusted so badly that they have disintegrated into dust and therefore each side is different. I need to know if anyone can help by advising me what measurements I could use to install new shims from scratch or any other advice they could give me.
Old Apr 26, 2014 | 06:49 PM
Sayfoo's Avatar
Sayfoo
I think that you will have to end up getting a rear end alignment. So, I would just center the arms and make sure that the shims take up all the slack, then head to the alignment shop. Bring any extra shims in case they need thinner or thicker shims to make it right.
Old Apr 26, 2014 | 07:46 PM
cagotzmann's Avatar
cagotzmann
It is normal that you dont have equal amounts on each side.
Unless you can do your own alignment make them as close as possible to original. Then take the car in for a 4 wheel alignment.
Old Apr 26, 2014 | 08:58 PM
Dodosmike's Avatar
Dodosmike
I recall reading somewhere on the forum that you'd use the thickest possible shims on the inside and "fine tune" the alignment with the thinner shims on the outside. Thats no fact, but what I recall reading. Might've been vice-versa.
If I can find the link ill repost it here.
Dodosmike
Old Apr 26, 2014 | 09:16 PM
gcusmano74's Avatar
gcusmano74
Get the car flat on the ground, rear toe shims removed, and the front wheels straight ahead. It will be easier to shove and twist the wheels around if you put six or eight sheets of shiny magazine paper under each tire.
Get yourself some stainless toe shims from any of the reproduction houses, first.
From the rear of the car, sight along the middle of each rear tire to each of the front wheels. With just a touch of toe in, you should just barely see the outside of the front tire. If you see a bunch of the tire, there is too much toe in. If you can't see the front tire at all, there is too much toe out on that side.
Without moving the rear wheels, solid stack the shims in the toe adjustment "box".
Now tighten the trailing arm bolt, and carefully drive to the alignment shop.
Good luck.
Old Apr 26, 2014 | 09:23 PM
'75's Avatar
'75
If your shims are rusted that badly, my guess is that the bolts are probably rusted into the bushing sleeves and you will end up sawing them out and replacing the bushings too.
Old Apr 26, 2014 | 09:31 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Another maybe......
I read that once you determine how many shims are needed on each side of the trailing arm the very thinnest of the shims need to be sandwiched between the thicker shims when they are installed as a "pack" so they won't get mangled because of the snug fit on each side of the trailing arm.
Old Apr 26, 2014 | 09:36 PM
gcusmano74's Avatar
gcusmano74
Originally Posted by doorgunner
Another maybe......
To Dag Nabbed Trailing Arm Shims.
