Timing -69 350/300hp
Just me, I'd look for a total of 36* at 3000 RPM and let the initial fall where it wants to. But that's also with a curve kit and maybe a little modification to the stop bushings.
Have the 36* come in by 3000 rpm.
Page 137.
According to this document, your car came equipped with distributor part number 1111490. This distributor was designed to provide 26 degrees of mechanical advance, if I am understanding the chart correctly (4 degrees initial, 30 degrees all in at 5100 rpm) The vacuum advance provides 19 degrees of advance. These numbers are all hypothetical you'll need to measure to make sure of them, the parameters on your car could be different due to production tolerances, and who knows, somebody may have replaced the distributor. You never know.
So, doing some quick math indicates that if you set your initial at 10, you should get an all in timing of 36 degrees. Re-curve the distributor so it comes in by 2500-3000 rpm, instead of the stock 5100 rpm. Problem: The stock vacuum advance canister, at 19 degrees of advance, will give you 55 degrees at cruise, which may be a bit much (52 is generally accepted as about the most you want to go) replace the vacuum advance with a unit that provides about 16 degrees of advance, and you should be just about optimized. Send an e-mail to Lars and ask for his paper on vacuum advance units to find out the part number of the one you need. Use manifold vacuum for the vacuum advance, and your timing at idle should be about 26 degrees, which is about right, too.
So, to summarize: re-curve distributor, replace vacuum advance unit, use manifold vacuum for vacuum advance, and set initial at 10 degrees. This is all theory, you'll have to measure with a timing light to verify, and make changes accordingly if need be.
Scott
