Corvette 82 Crossfire
Old Apr 28, 2014 | 08:50 AM
mohd2116's Avatar
mohd2116
Default Corvette 82 Crossfire
hi guys , im facing problem with a corvette 1982
crossfire the he change the exhaust system to hooker side exhaust
and he used the car for 6 months without O2 sensor and the car is smoking from exhaust black smoke too much
he drop it to my garage and i fixed the o2 sensor but the car still smoking !!
any advice guys ?
Old Apr 28, 2014 | 11:41 AM
hugie82's Avatar
hugie82
Harley riders are running into the same problem with open exhaust. In between pulses, oxygen swirls back into the exhaust steam. This gets picked up by the O2 sensor.
You either have to baffle the side pipes or return to a full exhaust.
Old Apr 28, 2014 | 05:33 PM
mohd2116's Avatar
mohd2116
it means there is no solutions to fix this problem without back to original exhaust !!
i fixed the o2 sensor on the passenger side on the collector , this is fyi
Old Apr 28, 2014 | 07:31 PM
jbaker434's Avatar
jbaker434
I have the same car and exhaust, you have to use a heated o2 sensor the computer will never go into a closed loop. Are you getting
a CEL ?
Old Apr 29, 2014 | 08:52 AM
jdp6000's Avatar
jdp6000
a CEL ?
You need the heated O2.
Is it still a crossfire setup?
Jim
Old Apr 29, 2014 | 09:17 AM
mohd2116's Avatar
mohd2116
Jim
yes it is still crossfire , can you please give me the part number or which O2 sensor should i use !!
please guys hurry up i really need it urgent
Old Apr 29, 2014 | 10:12 AM
jbaker434's Avatar
jbaker434
I used a Bosch 15717. Got it at advance auto. Mine is located on the passenger side collector a hair above the 3 o'clock position, angled slightly downward to keep condensation from getting inside. There are 3 wires on this sensor. Ground, switched hot and signal. Once computer sees correct o2 count should lean out. Hope this helps, mine has works perfect for almost 2 years.
Old Apr 29, 2014 | 10:16 AM
jbaker434's Avatar
jbaker434
By the way if your still running crossfire you should have gotten a check engine light. If your not than either your bulb is out or the PO disabled it somehow.
Old Apr 29, 2014 | 08:04 PM
82 beerhunter's Avatar
82 beerhunter
I have hooker side mounts with the max flow inserts.the o2 sensor is about 3or 4 inches from the primary exits on the driver side no issues with cel or smoking rich.slight chevy puf when you first start it after sitting for a few days or so ,other than that no problems.make sure the sensor is grounded good if its a single wire.
Old Apr 29, 2014 | 08:33 PM
jbaker434's Avatar
jbaker434
I used the OEM sensor after I installed the exhaust. The problem I had was at cruise speed the cel would go off and on until I got some heat on it. I had the laptop hooked up and the data capture showed a constant cycling between open and closed loop. Installed heated sensor, problem went away and car runs great. I hope this helps. I joined this forum after I bought this car, great amount of knowledge here.
Old Apr 29, 2014 | 09:07 PM
hugie82's Avatar
hugie82
It won't throw a check light unless the o2 can't see the mixture it's looking for or if it's stays in open loop. Heated sensors will get you into closed loop but if it's still picking up fresh air inside the side pipe, you still have a problem. As much as we love open side pipes on the street, I would still go with the slight baffling as suggested above. It may even cost the same as switching to heated sensors with less work or hassle from the cops.
Old Apr 30, 2014 | 01:27 PM
mohd2116's Avatar
mohd2116
as i checked the Bosch 15717 it has 4 wires so what is the 4th one for !!
Old Apr 30, 2014 | 01:59 PM
qwank's Avatar
qwank
the heater ground of course. hook the heater wire up to 12v ignition source. and ground the heater ground to the chassis.
I have a heated sensor on my '81 also with my side exhaust.
Old Apr 30, 2014 | 09:21 PM
jbaker434's Avatar
jbaker434
Sorry, try 15726.
Old May 2, 2014 | 05:54 AM
mohd2116's Avatar
mohd2116
Sorry, try 15726.
i ordered this o2 what u mentioned and i will fix it then will tell you what happen ,, hope it works thank you
Old Jun 16, 2014 | 08:05 AM
mohd2116's Avatar
mohd2116
Sorry, try 15726.
i received the O2 sensor and it has 3 wires one blk and 2 white ,, how should i fix it ??
Old Jun 16, 2014 | 12:36 PM
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
Just curious, where are you located?
To Corvette 82 Crossfire
