HELP! BBC 69 with ALUMINUM Heads ???
Hi guys,
Have a 69 convert putting a 454 in with ALUMINUM heads...I am planning on running side pipes, BUT LOVE THE stock steel covers (good to avoid BBQ flesh!) vs the crazy pipe.
Apparently am told factory-style side pipes will NOT work with ALuminum heads on a BBC...
1) Anyone do a BBC with AL heads AND factory style side pipes?
2) ANyone using factory steel covers??
3) Or brake booster issues with AL heads??
Heard there are fitment issues...please let me know asap....
Thanks!
Thanks!
Im assuming everyone is saying the exhaust wont work because of raised exhaust ports and the valve cover and booster wont fit because of higher than factory valve cover rails. I think before anyone can answer any questions youll need to let us know a little about the heads in question, what brand, model and specs?
Hi guys,
Thanks!
Thanks!
I have a BBC (ZZ502) with Aluminum heads with factory sidepipes. I have the factory manifolds too, no issues. I don't have power brakes.
Ok. They r basic pro comp alum heads. Engine builder (Steve Coil Racing engines) takes their alum head w Nothing on it. He does all the construction on valves, valve job, honing, springs, rockers, etc. he uses their basic head for this.
I am cool w stock valve covers. And i have power brakes. Hedman has the right heqder, but bc of raised exhaust ports (0.4 raised) that makes it 0.4 too much. Qccording to hedman rep, that reason for raised is why it is not compatible as bolt on. Apparently they hug pretty tight to the frame rail.
So...if that makes the header .4 too short to clear---either headers get .4 longer or engine gets .4 shorter...any way to use engine cradle/horns (go on mount) to lower? Or will cause more issues down drivetrain?
I could go shorty or stock manifolds BUT they will steal 30-50 hp...??
I'm kind of in the middle of a build and plan on using raised port BBC aluminum heads. I set a bare block in the car, put a set of raised port heads on with a pair of thick copper gaskets. All this just for mockup. The Hooker side exit headers fit just fine. Little bit close to the steering box and the clearance between the frame and the primary tubes was a little closer, but they did fit. The heads' ports were about .250 over stock height, and then I figured the two gaskets made about enough to cover a .300 raised port with a little bit extra. Not exact by any means, but close enough I'm comfortable spending north of $3k on heads and not having to replace the headers too. My stock rocker covers are still up in the air- the drippers will hit the rockers, but that's not a tough fix at all. A set of knock-off covers without the drippers and that's done.
TimAT...you are using the same hooker side pipe setup as in the your avatar?
Do you have power brakes?
I was planning on using Hedman headers
http://www.summitracing.com/parts/hed-68216/overview/
the tech said they will NOT fit because of the 0.4 raised AL head exhaust ports make these too short to clear the frame...because i want to continue using the factory side exhaust steel covers....to prevent BBQs...just looking for anyone who has done this?
Thanks,
R
Thanks,
R
i would say, you won't know until you try it. they may just go on fine or you may have to tweak them a little. but i guarantee somewhere someone has done it.
That is what I figured...but talking to the manufacturer they SPECIFICALLY said it will not work. it is apparently contraindicated in that application.
sucks...I do not want to do shorties...b/c will kill my top end HP about 30 HP...
I wouldn't want to do a nice build and choke it with the wrong exhaust either. I would seriously talk to your builder and see if he could use the heads he planned for you on another engine. If yes, I'd grab the Brodix heads and make great power while solving the header problem.
they specifically say lots of things, to cover them selves.
Edelbrock specifically says an R.P.M air gap intake won't fit under the hood of a 79 corvette, it fits under mine with a 1/2 in spacer. your just going to either accept their opinion or prove them wrong, i can tell you whats more rewarding.
very true...
spoke with him...he said fine, but the difference in cost for the other heads is 1500. so really it becomes $1500 for 30 or so HP...
I agree with proving them wrong...but had a couple reps say they will not work.
what about getting custom headers made? wonder what that cost would be?
or get a GREAT Shorty header?
I'm dropping in a 454 with Pro Comp heads, Headman Headers and stock valve covers. Don't have it in the car yet so not certain of Header fit (Nothing a welder won't fix)
I'm running 2.5" exhaust back to Magnaflows
Exhaust port is raised +.625”
You should be able to make the sidepipes work
Hwcoop---do u have power brakes (booster)?
I am leaning towards ordering & seeing...anyone know if u can "slightly" bend ceramic coated?
I have heard i may have clearance issues around the steering box but figure i can modify my headers if need be....mine are just painted
