carb question, Lars and others
Old Apr 30, 2014 | 05:25 PM
chrisviktorjakematt's Avatar
chrisviktorjakematt
Default carb question, Lars and others
I just looked up the model number of my holley carb installed by po. 80555-1. My research shows this is a q jet replacement 4 truck motors!!!???? It appears to(based on my readings of lars post) to have non adjustable floats. Am I screwed with this thing or will it be ok?
Old Apr 30, 2014 | 06:39 PM
wilcar's Avatar
wilcar
No, but you have to remove the float bowls to adjust them I believe.
Old Apr 30, 2014 | 07:06 PM
7t9l82's Avatar
7t9l82
correct, they adjust like the floats on the 600 holley. remove the bowls . those carbs when set up run well.
Old Apr 30, 2014 | 07:56 PM
chrisviktorjakematt
Default reply
OTE=7t9l82;1586790447]correct, they adjust like the floon the 600 holley. remove the bowls . those carbs when set up run well.[/QUOTE]
Ok that sounds ok, pita to remove the whole bowl assembly. I was afraid that being a truck carb was going to be the kiss of death.
To carb question, Lars and others
