Tach quit
Old Apr 30, 2014 | 09:56 PM
Doug Dame's Avatar
Doug Dame
2nd Gear
Default Tach quit
I removed dash to repair speedometer cable, it went OK, After getting back together the Tach needle is stuck at 5000 and wont work. It worked fine before ! All I did was unhook wire to remove dash panel and hook back up when going together. What happened and whats the fix ?
Old May 1, 2014 | 09:10 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
What model year? Tachs are mechanical through 74; electric after that.
Old May 1, 2014 | 08:23 PM
Doug Dame's Avatar
Doug Dame
2nd Gear
It is electric car is a 1976
Old May 1, 2014 | 08:28 PM
LannyL81's Avatar
LannyL81
The contact patches on the flex circuit on the back of the speedo / tach where the connector plugs-in are prone to breaking and curling-up....not making contact.
Check there.
To Tach quit
