68 horn contact
Old May 1, 2014 | 12:43 PM
AWilson's Avatar
AWilson
Default 68 horn contact
I looked for an answer to this one. There is a lot of horn issues but I didn't see mine, of coarse! My horn contact was missing. I just bought a new horn contact. But when i install it, on top of the steering wheel as I believe it goes, the prong underneath is short by a good 1/2 inch to reaching the spring loaded rod? The rod sticks through the hub about 1/2 inch. Is that correct? I can bubba it but would like to do it right. Any insight?
Yes, horn sounds when I ground the pin. Just cant get the contact anywhere near the pin with the contact!
Old May 1, 2014 | 02:15 PM
DZRick's Avatar
DZRick
Not sure if this will help but here's a picture of mine. Hopefully you'll see something that looks out of place on yours.
Old May 1, 2014 | 02:58 PM
gbvette62's Avatar
gbvette62
Do you have a tele column? The tele column uses a different contact, than the straight column. The tab on the bottom of it is longer than the tab on the contact for the straight column.
Old May 1, 2014 | 03:58 PM
AWilson's Avatar
AWilson
No, I do NOT have a tele column.
Old May 1, 2014 | 04:07 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Someone may have taken the original parts out and replaced them with the wrong parts, which is the problem I have with my '68 straight column horn button assembly being 1/2" too short to make contact.
I ordered a replacement horn contact assembly kit for a 1968 Corvette/Straight column ONLY from GRANT STEERING WHEELS.
I have not tried to install it yet.
Old May 1, 2014 | 10:50 PM
AWilson's Avatar
AWilson
well I plan to try to figure it out this weekend. Ill keep you posted.
To 68 horn contact
