question on installing headers
Old May 2, 2014 | 08:20 PM
jaybird81's Avatar
jaybird81
Default question on installing headers
I bought a set of headman headers regular length (not shorties), I am going to install them tomorrow. the car is an 81 with ac. Is there a trick to installing them? The car is a 4 spd if that matters. Any advice would be greatly appreciated. Thank you.
Old May 2, 2014 | 09:06 PM
qwank's Avatar
qwank
no tricks. just remove and reinstall.
They go in from the bottom, and there should be plenty of clearance to get them in.
Pull the starter out, It makes getting the Dipstick tube back in a little easier.
you'll have to unbolt the A/C compressor also. and you'll need to reuse the spacer and bolt on the right front header bolt for the a/c mount. you may need to add washers behind the spacer so it's the right length.
MrJlr's Avatar
MrJlr
Remove spark plugs and install from the bottom
Might have to remove your oil dip stick tube as well.......
Old May 2, 2014 | 09:08 PM
speedreed8's Avatar
speedreed8
disconnect the battery, since you'll be working around the starter area. safety first.......
TimAT's Avatar
TimAT
And the clutch z-bar (cross shaft)
Old May 2, 2014 | 09:38 PM
scottyp99's Avatar
scottyp99
Liberally spray the exhaust manifold bolts with a good penetrant tonight, let it soak in overnight. Tomorrow, utter a short prayer to whatever deity you worship, asking him/her to not let the bolts snap. Good luck,
Scott
Old May 2, 2014 | 09:52 PM
68Thunder427's Avatar
68Thunder427
but check the starter first. I had to pull my header off to change out my starter wasn't enough room to get it in and out.
Old May 2, 2014 | 11:47 PM
DZRick's Avatar
DZRick
I find it makes things easier to put a couple studs in the heads to hang the headers from while starting the rest of the header bolts.
To question on installing headers
