Strange 82 Tach Problem
Old May 5, 2014 | 10:19 PM
Midnightoil13's Avatar
Midnightoil13
Default Strange 82 Tach Problem
I've searched through the posts and have tried most of the suggestions. OK to the point. So the tach will zero with the ignition on, will read about 500 rpm when the car is running at idle. But while in park, i can rev the engine way up but can never seem to get past 2500 - 3000 rpm nor will it go higher if driving and stomping the gas. So the ground and 12v are fine. From 12v to signal I get about .2v at idle and 1v at close to redline. I don't have the filter at all. I tried replacing the board with one from wilcox and the needle may work sometimes, may not work, go from way below zero to way beyond 7000, or just act the same as the original board. So do I need the filter, an actual new tach, a new tach and board or is there something else i might be missing?
Old May 7, 2014 | 06:34 AM
jaysonb's Avatar
jaysonb
My tach was reading high, so I just put in a Wilcox board over the weekend, and also put a filter in, the tack is all over the place now. I set it at 0 with the key on, and it changes now every time I turn it on, it goes up and down at a stop light now with the blinker on. It worked fine before, just read a little high. Good luck!
Old Sep 24, 2014 | 12:54 AM
E.T.D. Corvettes's Avatar
E.T.D. Corvettes
C7 & C8 Events Correspondent
2020 C8 of the Year Finalist - Unmodified
2020 Corvette of the Year (track prepared)
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
I just changed the tach board on my 1980 and now it is doing the same as yours. Gets to 3000 and bounces around there, but won't go higher. Anyone know why?
Old Sep 24, 2014 | 09:11 AM
JimLentz's Avatar
JimLentz
I changed my tach board due to the tach reading wrong. When I put it back together the readings were very erratic. In my case the problem was the nuts holding the tach board (ground) weren't fully tight. I had to take the dash completely apart tighten the nut and it has been great since then.
To Strange 82 Tach Problem
