I posted earlier about my newly rebuilt 427 running on or dieseling. I have checked and done all the recommended things. Timing is right on, carb has been rebuilt, idle set at no more than 750. All this done by a very reputable old time hot rodder, with dieseling being the complaint. I still have some dieseling. So the last resort suggestion by Lars and others was a throttle stop. Does anyone know of the "best" one to buy? "Best" being defined as getting the job done once and for all.
Found the earlier post http://forums.corvetteforum.com/c3-t...dieseling.html
Looks like you never answered some of the questions.
What is your initial timing with vacuum disconnected?
Are you running ported or manifold vacuum to the distributor?
Did you adjust the secondary throttle stop on the passenger side of the carburetor, 1/2 turn from fully closed.
I had this problem with my (then) freshly built 489 stroker. Put it down to two things - fairly rich idle mixture (needed due to cam choice) - and with the new heads, until they had a thousand or so miles on them and some goog old fashioned carbon build-up, 'high spots' like the sharp edges of combustion chambers and perhaps valve pockets were creating 'hot spots' and the ensueing 'running-on'. Not a major issue now - can happen very occasionally.
Melwff- #1- I believe the timing is set @16. I just had my engine builder set it on the dyno. Plus the guy that just rebuilt the carb. said he checked it. I just have an old time timing light and not one of those fancy ones, which I believe is needed for this job. That's mainly why I left it up to the pros. #2- the vacuum line is hooked up from the vac advance on HEI dizzy to front of carb. #3- I have not touched any adjustments. Again, I was leaving it up to the shop that rebuilt the carb. It was/is running good besides the dieseling, so I really didn't want to mess with it. Besides, as you can tell, carbs are not my strong point !!! (Holley 750 CFM DBVL pumper.) Car is at front end shop right now getting front end rebuilt and aligned. I will see about that secondary adjustment this weekend when I get the car back. The good thing about all of this is I am about "through" (yeah right!!) with this "resurrection".
Thank you very much for helping me. I thought about just bringing it back to the shop that just did the carb. But I figure if he knew how to correct the dieseling, he would have. That was the initial complaint. Guess I'll give it a try now.
Back when you posted you never answered this question.
On a new engine I would say that your spark plugs are the wrong heat range and the tips are so hot that they are glowing causing the run on.
In the last couple of months I have rebuilt two 427/390's To give them some more get up and go. New big blocks have lots of friction and run hotter. I start out with two ranges colder.
Another thing many old time mechanics don't understand timing or ignitions even though they claim to. If the mechanic set your timing at 16 at or near idle. 99% he doesn't understand initial vs full advance and adjusting the mechanical advance curve to limit the total
I will try some "colder" plugs. A cheap, easy, thing to try. Can't hurt.
As far as timing goes, I don't really know the degree that it is set. Like I said, I left that up to the engine builder AND it was double checked by the mechanic that rebuilt the carb. The engine builder, Terry Walters, from Roanoke, Va. is a superb machinist. He has a stellar reputation and has been at this for over 30 years. Believe me, he knows his stuff!!! Chevrolet even farms out "new" motors to different machine shops around the country to try different parts combinations on a dyno. His shop has a 58something (572 maybe) CI. chevy engine right now that he is testing for Chevrolet. They are allowed to use different heads, intakes, etc. to see what aftermarket parts work good. He told me he currently has more than 100 hrs. of testing on that engine. My point is simply that the timing is not the issue. Now maybe the vac. advance or some other aspect of the timing is off or not working, but to question Terry Walters timing is like asking if the pope Is Catholic!!!!!
I will try the plugs though. Thank you for the suggestion.
I am having a hard time finding plugs. Can't believe it. Are these "colder" plugs all that rare? Only # that Advance Auto had was Autolite 403. None available unless I order em, which I guess I'll have to do. Auto zone didn't even list a normal plug for a 427!!! I think I just got an incompetent counter person!!! Anyone know the brand and some #'s for 1 step colder 427 plugs? Thanks PS- Ordered the throttle stop. Tired of this problem!!! Can't put car on market for sale with a dieseling engine, even if it is brand new!!
