Tunnel Ram???
Old Jul 20, 2002 | 04:45 PM
Smitty's75's Avatar
Smitty's75
Default Tunnel Ram???
I can't really get answers to this on the C4 forum,,,,I'm building a 427 small block, Dart Pro 1 heads, quite a healthy cam, with a 112 LSA,,,700R4 trans. I want to run a Weiand street tunnel ram with 2 600 CFM Holleys,,,anybody out there running a tunnel ram on the street, if so how streetable is it,,,read lots of articles on the set-up BUT that's not really hearing from anyone who's actually running it. Alll the help would be appreciated!
Old Jul 20, 2002 | 04:50 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: Tunnel Ram??? (autoxer)
I had an older car with a tunnel ram. It's not streetable. Unless you like crappy starts, no low end power and the worst driving experience ever, stick with a mini ram, or an intake like the air-gap and a single 800 CFM carb. They don't even start making decent power until about 4000 RPM anyway.
Just my experience and my opinion.
[Modified by BSeery, 1:51 PM 7/20/2002]
Old Jul 20, 2002 | 05:03 PM
Corey_68's Avatar
Corey_68
Default Re: Tunnel Ram??? (BSeery)
A street car with a tunnel ram is "All show....and No Go" to me. Great for the strip, but a VERY bad choice for the strret. A civic would probably pull you off the line, you'll have NO TORQUE until 4,000. But after that, Hold On! :lol:
Old Jul 21, 2002 | 12:50 AM
INTIMIDATOR ZO6's Avatar
INTIMIDATOR ZO6
Default Re: Tunnel Ram??? (Corey 68)
:seeya I ran a Edelbrock Performer 2.0 with a 750-CFM Holley on my 454 Big Block found it be a very good combo with a mild GM hi-performance cam! The only problem was I needed more cfm...850 CFM! :yesnod:
I have to say that with the right combo you could make it streetable. that means; the correct cfm carburetors, stall speed converter, rear gears, the correct cam will help for low to mid range torque so the comment of no torque is :bs I have yet to be beaten off the line by a civic! :D I now run a Comp Cam 280H Magnum, a 2200 TCI converter, 2-450 CFM Holleys, Edelbrock Street Tunnel Ram. :yesnod: I can tell you that if I hit to many traffic lights or just idle too long it will start to run too rich ...but a good run thru the gears clears it up quick! :D :D :D
Old Jul 21, 2002 | 01:15 AM
Schmucker's Avatar
Schmucker
All I've really heard is that they are harder to start with the two carbs. Hot Rod I think did an article about a good amount of tunnel rams for the street.
Old Jul 21, 2002 | 03:48 AM
Corey_68's Avatar
Corey_68
Default Re: Tunnel Ram??? (Schmucker)
Intimidator454
I will digress saying a street tunnel ram has no bottem end. In a big block you CAN have streetability with all the low end torque, it's more forgiving. The SMALL BLCOK tunnel ram, suffers a great deal more on the street. But even still, gears and a high stall will take care of that. :yesnod:
You better watch those Civics now....... j/k :lol: :lol: :lol:
Old Jul 21, 2002 | 10:07 PM
INTIMIDATOR ZO6
Intimidator454
________________________________________ ______________________
Point well taken a Big Block does have more bottom end! :yesnod: I think maybe we ought to talk him into going with a 8-71 Street Blower instead! :yesnod: :cool: :lol:
Old Jul 21, 2002 | 10:10 PM
Schmucker's Avatar
Schmucker
Default Re: Tunnel Ram??? (Intimidator454)
Hell yeah, a nice Weiand 8-71 blower is the way to go. The only disadvantage is the blind spot created by it, but he already isn't bothered by that if he wants a tunnel ram. Just get a blower and set it up for the fastest 0-80mph time you can. Gas mileage be damned, let's roast some ricers.
To Tunnel Ram???
