81 headlights stuck in up position
Old May 13, 2014 | 01:03 AM
Troy Driver's Avatar
Troy Driver
6th Gear
Default 81 headlights stuck in up position
Just bought an 81 and the headlights are stuck in the up position. Previous owner thought it may need new actuators. So I didn't beet around the bush and replaced all the components. Actuators / Actuator relays / check valve and headlight switch. Lights still stay in the up position ???? I've checked and double checked the lines to make sure they were in the correct position and all is good...... What am I missing????`
Old May 13, 2014 | 01:44 AM
FireballXL5's Avatar
FireballXL5
It there a hiss under the dash when the car is running and the light switch is off?
There's a little plunger under the center dash, make sure it's pushed in/up... That fixed my issue. Lol
Old May 13, 2014 | 10:13 AM
Troy Driver
6th Gear
Default stuck headlights.
No hiss under the dash
Old May 13, 2014 | 10:21 AM
jdp6000's Avatar
jdp6000
Did you check the plunger?
Jim
Old May 13, 2014 | 10:25 AM
Peterbuilt's Avatar
Peterbuilt
Double check that all the hoses are connected correctly.
http://www.corvette-101.com/vacuum.htm
Old May 13, 2014 | 11:05 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
you need to determine if you have a mechanical issue ?... or a vacuum control issue ?
if you pull the vacuum lines off of the headlight actuators, then you can manually move the individual headlight bucket up and down,
via the actuator rod, Not the bucket.
when the they go up, they pass thru a camed overhinge, which is backed by a spring. and lock into the upright postion,
very carefully (don't pinch your fingers) you should be able to manually push the actuator rod fully down, and fully open,
releasing them from upright postion will require a bit more push on the rod, to get past the spring cam over. good luck...
Old May 13, 2014 | 11:24 AM
Troy Driver
6th Gear
Default stuck lights
Jim
No... How do I check it?
Old May 13, 2014 | 11:33 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Troy Driver
...What am I missing?...
Probably the headlight over ride under the dash. Your owner's manual shows it and explains what it does.
Old May 13, 2014 | 11:35 AM
69Vett's Avatar
69Vett
"the Plunger" is a vacuum control switch directly under the steering wheel dash.
It is a head light override switch, which commands them them to stay up.
it pushes in, or pulls out, pulled out commands headlights up, pushed in is normal mode.
in normal mode when you turn on the light switch the headlights should open and close, with the light switch.
if the override under the dash is pulled out, ...headlights stay up.
Old May 13, 2014 | 11:36 AM
hyteck9's Avatar
hyteck9
There are adjustment screws on the outer frame on each of the headlights.
As the lights go up, these adjustment screws press in to the frame and provide the opposing force to "lock" the cam action hinge in to place.
With the car off, crawl under the car, pull down on the hinge to collapse the light. (be careful not to pinch yourself, you will need to pull reasonably hard.) look for the adjustment screw closest to the fenders on each side and turn them in to shorten its length. It is creating too much pressure and the actuator can not overcome it. A lot of people think the screw adjustment has to lock HARD to keep the lights from going down when they encounter head wind at highway speeds... they are incorrect. only a quarter turn past "initial" surface contact is needed.
Old May 13, 2014 | 12:45 PM
Troy Driver
6th Gear
Thank you all for the help. I am able to lower the lights manually if I disconnect the vacuum line from the check valve. The plunger is in the up position. And the headlight switch is off. But when I hook the vac line back to the check valve the lights pop up. Do plungers go bad????
Old May 13, 2014 | 01:41 PM
FireballXL5
Here's the Wilcox technical data sheets I have been using to sort out a LOT of my issues... VERY INFORMATIVE!
http://willcoxcorvette.com/repairand...a638e6eced32b8
Old May 13, 2014 | 02:28 PM
Troy Driver
6th Gear
Default Stuck Lights
Awesome....... if this info doesn't help I'm putting in electric moters
Old May 13, 2014 | 02:31 PM
FireballXL5
The stock system works fine, once you troubleshoot your issue... And I thought you JUST replaced all the stock hardware... Are you going electric motors after all that time and money because you can't get em to work yet? There are still other things to check on your stock system that may be simple to fix now that you've done the rest ... Such as vacuum lines collapsing under pressure and not allowing the canisters/actuators to do their thing...
This is the first I've read if going electric motors for your situation... Or did I miss something?
Duh... Just re- read your post... I'm sure you can get the stock setup to work... I know I would after all you've done already ... It would be a battle I would REFUSE to lose at this point. Lol
Old May 13, 2014 | 02:38 PM
scottyp99's Avatar
scottyp99
Here is everything you need to know to understand how the system works:
http://forums.corvetteforum.com/c3-t...tem-works.html
I guess there's nothing wrong with electrical actuation, per se, but it sure seems like an awful lot of time, money, and effort for a system that won't work any better than the stock system.
Scott
Old May 14, 2014 | 12:16 AM
Gale Banks 80''s Avatar
Gale Banks 80'
Back when I replaced all the vacuum lines on my 1980 I ordered a kit and a very large drawing showing the color coded lines. As I am the original owner I know that my original lines had never been messed with. The Drawing was wrong with its codes for the Actuators them selves. It would of been correct for a pre 1980, but not for a 80-82. Its been a decade or more since I did it so It's a bit foggy on what the difference is. I think the Vacuum canisters are reversed or something from the previous years.
An easy way to trouble shoot the system is to take a long hose from another vacuum source than Your Engine. This way You can listen for leaks. In your case though you have replaced everything so most likely something is hooked up wrong, probably before you. Take the temporary Vacuum line and hook it up directly to each headlight assembly and see if they work. I'll bet they do. Then just start working your way back to the Engine source.
Old May 14, 2014 | 12:38 AM
Troy Driver
6th Gear
Default Thank you to all... this forum rocks
Old May 14, 2014 | 12:40 AM
Troy Driver
6th Gear
I agree
To 81 headlights stuck in up position
