Tire wear, front, inner edges
I dont know a huge amount about tracking etc but on a car that has no wear in any of the suspension or steering parts could this be caused by either negative camber or excessive toe out? I havent taken her to be aligned yet but want to know what I am looking to be corrected.
A friend has suggested it is probaly too much toe out causing the wheels to scrub the inner edges and has said this could be rectified using the shims on the upper A arms.
Any advice appreciated.
Whilst reading another site, I found the following,
I know people have different ideas on what the alignment should be but what are the specs for a stock car?
Looking at VBP they state for the fronts on a daily driver, Toe 1/32" in, Camber 0° neg Caster 2.75°
Is this much different from GM specs and if so, which would be recommended?
