Tire wear
Old May 16, 2014 | 04:20 PM
manfroni's Avatar
manfroni
Default Tire wear
The new Goodyear tires are wearing on the inside. The car has just been aligned, and the new tires balaned. The tires are 255-60-15 on the stock alloy wheels. Too much air? The wear pattern is smooth just wearing from the inside of the outer treads. Thanks
Old May 16, 2014 | 04:22 PM
manfroni's Avatar
manfroni
Sorry, running 30 psi all around and the front and rear have the same wear patterns
Old May 16, 2014 | 05:17 PM
jotto's Avatar
jotto
I have exactly the same issue on the fronts and believe it an alignment issue....
http://forums.corvetteforum.com/c3-t...ner-edges.html
What specs were yours aligned to and was the wear apparent before the alignment?
If the tires were new but alignment was out they would wear. Was the car aligned when the tires were fitted and how many miles on them?
Old May 16, 2014 | 06:19 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
Inside wear and wondering - Worn or loose front wheel bearings will give you the same result.
Old May 17, 2014 | 06:33 AM
gcusmano74's Avatar
gcusmano74
Too much negative camber.
Old May 17, 2014 | 08:44 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
and also measure the Toe in case the fronts of the tires are "pointing" out slightly....once I learned how alignment works, I would always re-shim my tires if they started showing wear...now I can get 70,000 miles out of a set of BFGs....(50,000 with an occasional burn-out...LOL)
\-------------/ <<<<<<<<front tires TOE out of spec.(exaggerated )
>>>>I<<<<<<<centerline of chassis
I-------------I <<<<<<<<rear tires TOE set correctly
Old May 17, 2014 | 08:45 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Old May 17, 2014 | 09:48 AM
manfroni's Avatar
manfroni
The entire front suspension has been rebuilt and the alignment was "done to factory specs". Why would the rear tires have the same wear patters as the front? Any GOOD shops in the Cleveland area?
To Tire wear
