Hello everyone. I haven't been able to make any significant progress on my '73 in 9 months; due to me being at school. But I have a rebuilt TH400, new pump, new tranny lines, new shift control cable. After taking it out for a drive, the car seemed to lack power. I'd get to about 20 mph and if I tried to push on the gas hard, the car wouldn't go anywhere. It came to me that the gasoline was most likely bad. So as of 05/17/14 I drained all the bad gas in the tank, but not all that was in the fuel lines and filter, as well as a needed engine oil change.
Put new 91 octane gas and going to put a fuel system cleaner in on sunday. Been adjusting the modulator and thats about it. Frustrating to constantly jack the car up and not feel any results. Can anyone give me some pointers, or anyone have a problem similar as this?
have someone sit in the drivers seat, pull air cleaner. have them put gas pedal o the floor. look at carb. is it wide open? did you do the tranny rebuild or a shop? maybe cable for throttle fubar?
TH400 was rebuilt by a shop. Rebuilt to original specs, only modification was a deeper pan, and the transmission guy applied the correct longer pick-up tube. I don't believe the throttle cable has changed much since when I left it, but won't hurt to check. When I shift into second gear, the car has a little bit more pick up. However, I did notice something peculiar when I shifted into second. There was a hissing noise; I believe it was the vacuum because I adjusted it before going on my drive. But when I put back into third, the hiss stopped and the lack of get up comes back. All factors are being considered.
What do you mean no power ? Is it revving at all in first gear if you put it in manually and leave it there ? Is it hesitating ? If you floor it does it rev and go or does it not rev ?
In park can you race the motor ? How is it in reverse can you hit it and spin tires or feel it pull hard ?
Engine is fine. When i have it in park I can rev it no problem and it runs healthy. The shifts are nice and smooth, no sign of major internal problem. What I mean by not having any power, is when I try to floor or it even a little bit, it doesn't rev and go, just seems stuck.
It sounds like a plugged exhaust which will do exactly what you are describing.
I also would check the linkage connection it is possible your not in gear completely or applying 2 gears at the same time because the detente is not moving the valve fully.
And lastly on an out side chance the trans filter could have fallen off or could be plugged the th400 filters use to cause issues.
I thought it was the linkage before. I felt that I wasn't fully engaged, when I shifted. Sometimes I couldn't even go into park! Like I said, new shifter control cable, and I adjusted the cable back to the position it was at before I rebuilt the tranny. Car performed just fine with the linkage in that position.
Exhaust isn't backed up because they're currently aren't any pipes, open headers.
That is the last thing I am going to check. Taking the pan off and checking if the pick-up tube hasn't slipped out.
