Headlight vacuum troubleshooting
Old May 18, 2014 | 02:10 PM
Mpls Funk's Avatar
Mpls Funk
Default Headlight vacuum troubleshooting
Hi all,
I have a 1970 small block. When I go to turn on my headlights, one of the lights (driver side) seems to take 5-30 seconds to pop up, and the passenger side really never does. It might get half of the way up after a minute or two....unless I am driving at a good speed, then they seem to pop up much quicker. They don't seem to struggle as much to go down.
I'm wondering if there is a good document out there that could step me through the system and how to check each component to try and figure out what is going on? Pictures would be good too as I have a lot to learn and don't know what each component is called.
Any help would be appreciated.
Old May 18, 2014 | 02:59 PM
Peterbuilt's Avatar
Peterbuilt
Default Does this help?
Many times the seal (grommet) in the actuator goes bad.
Here's a HOW TO so you can test each component.
http://www.corvette-101.com/vacuum.htm
Willcox has a HOW TO that covers the wiper door parts if you need it.
Old May 18, 2014 | 08:51 PM
Kacyc3's Avatar
Kacyc3
before you buy any parts to fix what ever is wrong look at doing the electric conversion post on here I have $70 in my conversion start to finish.
Old May 19, 2014 | 08:03 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Check the vacuum relay on the passenger's side.
Old May 19, 2014 | 02:23 PM
BBCorv70's Avatar
BBCorv70
I found all 3 vacuum relays leaking on my 70, one very badly. Replaced all three. Headlights pop right up now. The relays are easy to test with a hand held vacuum pump. Actuators can be tested as well.
To Headlight vacuum troubleshooting
