Need guru who knows engine harness-'68
Old May 18, 2014 | 02:48 PM
mcb55-210's Avatar
mcb55-210
Default Need guru who knows engine harness-'68
I'm usually on C1 forum, but my '62 had a '68 engine installed years ago. I pulled engine in January for detailing...found that the harness was in dire need of replacement. Whoever swapped the engine utilized the stock harness. Simple enough-I made one with the correct gauge/color wires that the factory schematic called out. Finishing hooking up the wires, but need reassurance that this is correct.
So, here's what I have...green wire (from + wire on coil/resistor) to the "R" on solenoid. Violet wire from ignition switch to "S" on solenoid. Black wire from ammeter gauge to ground. And, obviously, "+" from battery to the main lug on solenoid.
Is that the only wire I need going to the main lug on the starter? The car had also been changed over to a single wire alternator, which is connected to the hot side of the ammeter gauge.
I appreciate your guidance and assistance.
Mike
Old May 18, 2014 | 04:19 PM
68Thunder427's Avatar
68Thunder427
Mike
Mine has TI ignition and is a BB so the wiring is different. Here is the wiring diagram I have been using and there is a guy on C3 forum named papawana that can send you wiring diagrams also.
Old May 18, 2014 | 09:54 PM
mcb55-210's Avatar
mcb55-210
Thanks for the link. Just need to verify if my connections to the starter are correct.
Thanks!
Mike
Old May 20, 2014 | 07:57 AM
mcb55-210's Avatar
mcb55-210
Any thoughts?
Mike
Old May 20, 2014 | 11:02 AM
Peterbuilt's Avatar
Peterbuilt
Going by the 62 schematic you have it correct.
http://www.vetteprojects.com/bmv/mis...tte%201962.pdf
Old May 20, 2014 | 02:10 PM
mcb55-210's Avatar
mcb55-210
Thanks-that was a different schematic layout than the one in my AIM (which I don't have in front of me at the moment), but on my schematic I believe there was an additional wire to the solenoid.
Looks like I will be ok-thanks again!
Mike
Old May 20, 2014 | 03:30 PM
Peterbuilt's Avatar
Peterbuilt
The black on the ammeter does not go to ground, it connects to the battery positive on the solenoid.
Old May 20, 2014 | 04:02 PM
mcb55-210's Avatar
mcb55-210
On the same lug with the cable from the + Battery? (at least according to the 1962 schematic above!)
Mike
To Need guru who knows engine harness-'68
