Sidepipe kit for ALUM heads??
Old May 21, 2014 | 10:23 PM
Factor's Avatar
Factor
Default Sidepipe kit for ALUM heads??
Hi All!,
OK! built a 454 w ALUM heads, AND realized how hard it is to find a sidepipe/header kit...APPARENTLY the sidepipe header kits do NOT like aluminum heads because of the raised ports.
I put in a call to STAINLESSWORKS, but they do not manufacture them, AND may do a special run. Other than that, no leads.
need to figure out how to get something to work with the ALUM heads and stock sidepipe exhaust covers
anyone use a company that does this? thoughts?
Thanks! Always appreciate the GREAT INFO!
R
Old May 21, 2014 | 10:24 PM
Factor's Avatar
Factor
btw...69 vette...
Old May 21, 2014 | 10:40 PM
509 rat's Avatar
509 rat
Default call these guys
Originally Posted by Factor
btw...69 vette...
call sanderson headers. and mcjacks, then just have your high performance muffler shop fab up the rest of the exhaust, very easy to do have your stock covers there with you when making the side pipe part.
Old May 21, 2014 | 10:44 PM
GUSTO14's Avatar
GUSTO14
You might want to check with Stahl Headers. They do offer them for your car with a small block and have been known to build for special applications. Most have said their headers, particularly for side-pipes are outstanding.
http://www.stahlheaders.com/index.htm
Good luck... GUSTO
Old May 21, 2014 | 10:53 PM
509 rat's Avatar
509 rat
Default they just shut the doors
Good luck... GUSTO
got the e mail yesterday from judy, owners wife, or the other way around lol.and expensive but worth it .
Old May 22, 2014 | 10:26 AM
keithinspace's Avatar
keithinspace
? I run regular flavor Hooker sidemounts on my aluminum head 350. Heads are PBM Strike Force.
For a variety of reasons, I was having some issues sealing the exhaust flange. I ended up using Earl's Pressure Master gaskets...AMAZING. No blowouts, no leaks, no problem. A little expensive, but worth every penny for me.
Another thing I did was order the longest stainless ARP 3/8" header bolts I could get...1-1/4", I believe. That allowed me to grab more of the threads in the aluminum heads and make me feel pretty good about giving them some torque as necessary.
And be sure to use anti-sieze on everything. You'll gaul the hell out of those heads in a heartbeat.
Old May 22, 2014 | 10:44 AM
Factor's Avatar
Factor
GREAT INFO! thanks guys! Will start the inquiries!
Ron
Old May 22, 2014 | 11:21 AM
bashcraft's Avatar
bashcraft
Small block aluminum heads don't have raised ports like the big blocks do.
Several weeks ago, there was a thread about hooker sidemounts and raised port heads. It seems that they'll fit on some cars and others they won't. I stayed away from the raised ports when i built my 502 for just this reason.
Old May 22, 2014 | 03:48 PM
Factor's Avatar
Factor
makes sense...of course hindsight!
Old May 22, 2014 | 11:04 PM
TimAT's Avatar
TimAT
I'm looking at the same thing- I set a bare block in the car and then put a pair of .100 thick head gaskets on (+.200) and then heads with .250 raised ports. (+.250). My Hooker sidemounts bolted up no problem. I'm going to have to extend the factory "ding" in the primary tube, and they are close under the frame, but they DID fit. Bottom line for me is the .300 raised port heads won't be any deal.
Old May 23, 2014 | 08:56 AM
Factor's Avatar
Factor
WOW! Ok. my heads are .400 raised ports...
which hooker sidemounts do you have?
thanks,
Ron
Old May 23, 2014 | 10:32 AM
TimAT's Avatar
TimAT
Hooker ceramic coated (Jet Hot) with 2-1/8 primaries. No idea what part number they are.
Old May 23, 2014 | 11:30 AM
Flatout496's Avatar
Flatout496
Navigator
thanks,
Ron
I have a '68 bb with Hooker sidemounts also. Fits just fine.
Old May 23, 2014 | 11:34 AM
Flatout496's Avatar
Flatout496
Navigator
Forgot to say that I also have Dart Pro 1's with raised exhaust.
Old May 23, 2014 | 02:26 PM
Factor's Avatar
Factor
Great! thanks flatout!
i believe those headers come outside the car far enough where you cannot use the stock covers, right?
thanks,
Ron
Old May 23, 2014 | 03:33 PM
qwank's Avatar
qwank
Didn't we tell you to try the hooker sidemounts in your other two threads about this?
Old May 23, 2014 | 03:37 PM
Factor's Avatar
Factor
FLATOUT
what raised height are your DART Pro1's?
I have 0.400".....
thanks,
R
To Sidepipe kit for ALUM heads??
Old May 23, 2014 | 03:39 PM
Factor's Avatar
Factor
Yes, Qwank it was said...but want to use the factory shields...which is where the dilemma is.
I did get great info, and am hoping to work with stahl. -which I did not get in previous threads
just asking the question differently and getting more info.
thanks!
R
Old May 24, 2014 | 08:16 PM
74 vert's Avatar
74 vert
From: Where are the Smoky Mountain Cruisers? Not Correctly Restored Stingray
would it be possible to fab motor mounts to get some extra clearance?
Old May 25, 2014 | 10:43 AM
Flatout496's Avatar
Flatout496
Navigator
FLATOUT
I have 0.400".....
thanks,
R
I believe mine are .300. I don't remember having any trouble installing mine. Can't believe .400 would be a problem.
