Heater hoses
Old Jul 21, 2002 | 08:09 PM
John D.'s Avatar
John D.
Default Heater hoses
Does it matter which hose connects to fill tank on a 1971.
Hose from water pump to tank , then from heater to tank then from manifold to heater.
I do not have my heater core connected. So I was going from water pump to tank and from manifold to tank.
Does it matter which of these goes to which opening of tank.
Old Jul 21, 2002 | 10:45 PM
stingray72's Avatar
stingray72
Default Re: Heater hoses (John D.)
There are two different hose I.D. in question. The hose from the water pump to the expansion tank, and to the heater core is 3/4" I.D. The hose from the heater core to the intake manifold is 5/8" I.D. You cannot hook the 5/8" hose to the expansion tank, as the fittings are for the 3/4" I.D. hose. Fix or replace the core.
George
Old Jul 21, 2002 | 10:52 PM
Paul L's Avatar
Paul L
Your post is confusing. The 3/4" and 5/8" hoses do not go to the overflow tank. They go to the heater core. Please elaborate.
Old Jul 21, 2002 | 10:58 PM
Pete79L82's Avatar
Pete79L82
Default Re: Heater hoses (paul79)
Early C3's did not have the radiator cap on the radiator, it was on a metal expansion tank. That is what he is refering to.
Old Jul 21, 2002 | 11:02 PM
Paul L's Avatar
Paul L
Default Re: Heater hoses (Pete79L82)
Thanks Pete. I stand corrected ;) . Learn more each day!
To Heater hoses
