brighter headlights
dont waste your time with hid lights contact Daniel Stern for his advice he is a lighting guru. i just upgraded the wiring and used h4 housings with some Osham bulbs he sells and he has stuff for the high beams too. i won't influence you by telling you exactly what i used. lets just say driving at night is fun, and i will have a hard time driving beyond my lights
A set of good, name brand (Cibie, Marchal or Hella) E-code Halogen lights with Osram European bulbs and improved wiring (to improve the voltage presented to the bulb) will give your C3 all of the light you need to drive fast while not blinding on-coming traffic.
I put projectors and good white 6,000k (white not the distracting and less useful blue) hid bulbs in my truck and the difference was night and day.
Plus they use much less power than halogens while putting out more than twice the lumens over old halogen technology.... some halogen bulbs now use some of the gases to give the light a brighter whiter color temp but they are still a filament bulb. I've tried some of these. But its like comparing a 300 w incandescent light bulb with a 250w metal halide... no comparison.
Quality made Hid is superior and that's why all of the higher end cars are coming from the factory with them now.
With that said, I have had (4) Hella Euro Lead Crystal Lens lights with 55/60 watt lows and 100 watt halogens since 1983 on my 78...yes 1983! I rarely drive the 78 at night much but when I do it is portable daylight...albeit a halogen bulb, not the brilliant white light of HID's. The lights fit in the 78 buckets with very minor modification but do require a relay on the high beam side due to the 100 watt bulbs pulling more amperage than the stock headlight switch can handle without triggering the built in circuit breaker in the switch.
The headlight lense is the most important aspect of any lighting system, not necessarily the bulb intensity, especially with halogens. I have 2 HID conversion systems I use on my DD, one a 2008 Chrysler 300 and the other on a 2001 Pontiac Grand prix. On the 300 since it had the same projector used on the 300's with factory HID;s, the conversion to HID's was easy. On the the GP which has a crap plastic lense for halogens non projector, I went with this:
http://www.theretrofitsource.com
The system requires that you open up the factory light housing and fit their high quality projector lense into the factory light behind the the plastic cover....The result is unbelievable!!!! Lot of work but well worth it for a car I drive every day, often at night. The difference between the factory headlight with halogens and the HID projector is incredibly great...they are that good. The retrofit source allows HID projectors on any car using the factory headlight housing!
As for upgrading wiring with aftermarket HID kits..not needed since the HID require a voltage spike to start the HID but only pulls 35 watts when on...all wiring with 20 amp fuses is provided.
On my 300, I have had German made McClough HID's which have now been used on 2 Chrysler 300's (2005 AND presently 2008)...this kit cost $300 back in 2006 when I put them on the first 300...just goes to show AGAIN..you get what you pay for. The retrofit source projector/HID kit was $279 for the GP and these lights are better than the 300 since the projector from the retrofit source is a higher quality than the factory 300 projector.
