1969 427/435hp valve lash
Old May 26, 2014 | 03:22 PM
camaro00440's Avatar
camaro00440
4th Gear
Default 1969 427/435hp valve lash
I'm new here and need the stock valve lash for a 69 427/435hp ! any help would be thankful ! Mark
Old May 26, 2014 | 09:00 PM
Super6's Avatar
Super6
Intake/Exhaust Lash = 0.024"/0.028". Set "hot and running" per the 69 Chevy Chassis Service Manual.
Old May 26, 2014 | 09:19 PM
camaro00440
4th Gear
Thank you.....
Old May 26, 2014 | 10:51 PM
TimAT's Avatar
TimAT
That is what the service manual says.
You may have better luck, (and longer life for your feeler gauges) is you get it hot, shut it down and pull one cover and adjust the intake as the exhaust opens and the intake as the exhaust closes.
All I ever got doing it running was the ends chewed up on the feeler gauges. Didn't quite cut divots, but you could sure see where the end of the valve was.
Old May 26, 2014 | 11:05 PM
camaro00440
4th Gear
Sounds like this is the way I'm gonna do it...thanks
Old May 27, 2014 | 06:02 PM
Zoix's Avatar
Zoix
Default Valve lash.
Correction: Adjust intake valve when exhaust valve begins to open and adjust exhaust valve when the intake valve starts to close.
Old May 27, 2014 | 06:35 PM
Les's Avatar
Les
Once you know they're set properly, wait until the engine is cold (as in the next day or later) and measure them that way. Write it down and from then on you can use those specs to set them cold- much nicer.
Old May 27, 2014 | 06:40 PM
camaro00440
4th Gear
Thank you, that does sound like it would make it easier the next time !
Old May 28, 2014 | 07:43 PM
TimAT's Avatar
TimAT
That is EXACTLY why I have a sticker on the firewall to remind me. I've been adjusting valves like that since 1972---- and I STILL CAN'T REMEMBER..
Thanks for the correction!!
To 1969 427/435hp valve lash
