Electric Fan Help Please
Old May 31, 2014 | 02:28 AM
bence13_33's Avatar
bence13_33
Default Electric Fan Help Please
I used to run a really nice Flex-A-Lite dual electric fan setup. I loved them! I believe they were pullers and me being the wiring genius that I am(MAJOR sarcasm...terrible with electronics) I just wired them to a toggle switch so that I can flip the fans off during my 1/4 mile passes but use them in the water box and at the end of the track. I moved o GA for a few years and the car sat on the garage. I took it for a spin the one year and smelled electrical burning so I pulled off and it turns out that one of the fan motors seized up from sitting around for those years. I am now running my stock clutch fan and fan blade. What would be a good electric fan setup and is it possible to replace the bad flex-a-lite fan motor? Thanks!
Old May 31, 2014 | 05:18 AM
terrys6t8roadster's Avatar
terrys6t8roadster
Yes you can replace the motor. just contact Flexalite. Good people to work with. T
Old May 31, 2014 | 08:51 AM
SIXFOOTER's Avatar
SIXFOOTER
Replacing 1 fan motor should not be a problem.
Depending on how old the thing is you might consider switching to a dual Spall setup with a temp controller, let it do the work of turning them on and off.
To Electric Fan Help Please
