shifter lube?
Old Jun 1, 2014 | 09:18 AM
jrlaidle's Avatar
jrlaidle
1st Gear
Default shifter lube?
1974 muncie 4 speed got stuck in first gear. I tore apart the shifter and linkages. The shifter had what used to be grease I think lubricating it. It is now a crunchy pine tar consistancy. Anyway I am going to clean it all up and see if it is worth saving or of I should go with an aftermarket version. My question is what to lube the shifter with? It is exposed to all the road grime so I don't think grease is the answer. Thoughts?
Old Jun 1, 2014 | 11:07 AM
redvetracr's Avatar
redvetracr
Teflon spray (maybe) from PB blaster, grease attracts dirt
Old Jun 1, 2014 | 02:38 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
There used to be a product called "Tri-Flow", IIRC. It was a dry, Teflon based spray, and I used to see it sold in bicycle shops, among other places. LPS also makes a "dry" lubricant spray.
To shifter lube?
