Need help
Old Jun 3, 2014 | 02:00 PM
Bill Jones's Avatar
Bill Jones
Default Need help
I have a 1977 corvette which I just changed plug wires. I put MSD wires on and I check the OHMS on each wire. I did one wire at a time. I also went back to make sure all the wires are where they are suppose to be. The motor seems to run a little ruff. When I move the distributor the engine doesn't seem to speed up when you advance. The engine seems to stay about the same when the distributor is being moved. Any suggestions. Thanks in advance.
Old Jun 3, 2014 | 02:07 PM
AirborneSilva's Avatar
AirborneSilva
It does sound like you have your firing order off.
Old Jun 3, 2014 | 03:11 PM
dochorsepower's Avatar
dochorsepower
Did you change the cap and rotor too? Those need changing more often than the wires.
To Need help
