I have a 1968 corvette that I was having all the front rubber bushings replaced. While the front a arms were off decided to replace the front coil springs. The old springs free stand about 15 1/2 inches high. The new springs free stand about 12 1/2 inches tall. It has a 327 without ac. From what I can determine the 12 1/2" height is correct for stock replacement springs. Anyone know why the difference in height? Thanks for any information .
Is there a reason why you want stock springs? To answer your question the shorter spring would have stiffer coils to have the same ride height as the longer
not sure i buy into that in an automotive application. but i have seen worn out springs that were almost exactly the same length as the identical replacement indicating they didn't compress.
I wish I could, but I'm not a mechanical engineer. I had a mechanical engineer friend try to explain it to me once, but it was so over my head that he gave up and said just take my word for it!! But, here's the formula if you're interested
That formula is for the diametrical expansion and has nothing to do with the height. I can tell you that I have never seen a front auto coil spring get taller with wear. I can also guarantee that a coil spring will not start out at 12 inches and end up at 15. It just aint going to happen. The reason his spring is shorter is that it is a replacement non spec. spring, period.
