82 Fuel guage problem
Old Jul 22, 2002 | 06:51 PM
Chas 95's Avatar
Chas 95
Default 82 Fuel guage problem
Ladies & Gentlemen, I've got a two-tone blue 1982 Crossfire with a fuel
problem. Less than a month ago I had a new crated GM motor installed
and am very pleased with that. I have what seems like a fuel imballance
delimma. When I start the car up in the mornings it takes a minute or two
to warm up. My fuel indicator is jumping around the dial like a geiger counter. As I start acceleration the needle is jumping around, and while I know that during decleration some fuel will sloch in the tank causing the needle to move around - this anomaly happens will full
load power is on the engine. I've had the fuel pump, filter replaced. Any ideas on what the solution can be.
Thankx
Charles
Two-Tone Blue 82
Portland, Oregon
Old Jul 22, 2002 | 07:06 PM
page62's Avatar
page62
Default Re: 82 Fuel guage problem (Chas 82)
Most likely you have a bad fuel gauge sender, which is located in the fuel tank.
Old Jul 22, 2002 | 09:39 PM
terry82's Avatar
terry82
could it be a loose wire ?ground maybe?
Old Jul 23, 2002 | 12:36 PM
catfishjack's Avatar
catfishjack
The fuel gauge in my 82 (25,000 Original miles) does the same thing...
Old Jul 23, 2002 | 02:24 PM
Blues Mobile's Avatar
Blues Mobile
Default Re: 82 Fuel guage problem (catfishjack)
My fuel guage doesn't jump around, but my oil pressure does what you are describing. I'm still trying to figure that one out - I hope I don't have bad oil flow.
-Steve
Old Jul 23, 2002 | 03:56 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: 82 Fuel guage problem (70Shark)
Common problem. The sending unit's float arm wears out. The resistance becomes low and the needle will be all over the place.
Marck
Old Jul 23, 2002 | 04:57 PM
Chas 95's Avatar
Chas 95
Thank you all for your suggestions. I have to ask, can I do this myself or would you suggest that I take to a professional who can test it after the repair is done. I will ask my mechanic this afternoon to take a look at it. I truly hope this cure's what's ailing my baby.
Thankx again,
Chas82
Old Jul 23, 2002 | 05:38 PM
Twin_Turbo's Avatar
Twin_Turbo
You can replace the entire sender (a little expensive). It's relatibly easy. Remove the rubber grommet under the gas lid, remove the lid, undo the connector to the fuel pump, remove tuel lines, unbolt flange, pull the sender/fuel pump out. Rotate while trying to pull gently. It will only come out in 1 position.
Marck
Old Jul 24, 2002 | 05:35 PM
Chas 95's Avatar
Chas 95
Default Re: 82 Fuel guage problem Con't(Chas 82)
This morning I took my baby to the mechanic - its the sending unit. I've look'd at some aftermarket products (ZIP), (MID AMERICA) this thing
cost $359.00. It's kill'n me. I guess this was to be expected since it was
the original one put in 20 years ago.
To 82 Fuel guage problem
