Spreader Bar yes / no ?
The spreader bar will make a difference but as many modifications it will show mor the harder you drive and the stickier tires you have.
I cant guarantee that it will make a great change on an car with old worn out rubber bushings, soft suspension and old polyglass tires that drives around town.
But if you are dedicated and are going to DRIVE your car, yes get one.
Also, as mentioned above, I had the VBP unwelded spreader bar for 20 years since I could never get it to fit with my mechanical fan and pulleys. I finally sold it to a forum member for $50 who had a C3 without the mechanical fan and he used my unused VBP spreader bar in his application with no problems. I have had a speedirect spreader bar which is pre welded for SBC with mechanical fans and it fit perfectly. Easy to install and the best $100 i have spent on the suspension.
As for the 78/79 C3 frame being heavier than prior years, i have never seen any documentation supporting that claim. All the C3 frames from 63-82 are basically the same. I would expect that the C2 and early C3's frames would have more than adequate frames to handle BB/SBC's with big HP/Torque. The 78/79's weighted roughly 200-300 pounds more than the early C3's with half the HP-the earlier frame would easily handle the weight and dramatically less HP. If I had to wager, there is no difference in the basic structure of all the C3/C2 frames and rest frame manufacturers do not make any exception for the 78/79 frames.
In response to the CAFE mandate, Chevrolet decided that the first-stage of trimming back the Corvette would mean the elimination of some 250 pounds from the current design. Engineers considered every option to lighten the car’s structure while trying to maintain its structural integrity. As a start, the differential housing and front-frame cross-member were switched from steel to aluminum. Similarly, the aluminum intake manifold that had been previously used on the optional L82 engine was now included on the base L48 engine as well. Externally, engineers trimmed weight by using lower density roof panels, and by reducing the material thickness of the hood and the outer door skins. Exterior chrome was kept to a minimum, which meant the elimination of the crossed-flag emblems from the front fenders. Lastly, greater use was made of plastics throughout the car on everything from interior trim components to sub-assemblies in seats, and so on.
In addition to weight reduction measures, engineers also focused on getting the Corvette to produce better overall gas mileage results. The previously optional front and rear spoilers were reshaped and made an integral part of the bodywork. Additionally, the front grilled was raked back slightly. As a result of these changes, the coefficient of drag (Cd) fell from 0.503 to a more respectable 0.443. While this number was still not optimal, it was a notable improvement nonetheless. Additionally, urethane was applied during the molding of the body panels forward of the firewall and was also applied to the roof panels. This application resulted in improved surface quality, which also helped in the reduction of drag.
I've recently been getting serious about VBP products. Heck of a company and heck of a series of parts. All at a "fair trade" price.
Need to look at their catalogue again, though...think I missed the 'salmon kit'...
I did notice a big stiffness change when I first drove my roll cage equipped that previously had 9 and 11 inch 17 diameter wheels with some of the best tires made.
The spreader bar seemed like more a weight gain than any real help even at the track with slicks. But like I said before I followed the chevy power book and looked into the frame reinforcement kits before welding on mine.
I did get a crack in my frame where the lower A-arm rear bolt/ bar assembly attaches. I directly attributed it to our local track that has overly aggressive corner cement bump strips, my 295 width front slicks, and 700# springs and QA-1 dual adjust shock compression settings on the right front. I welded ground flat and added fish plates on both sides so it would not happen again.
I don't know much about later model C3s.
What parts are these?
"front-frame cross-member were switched from steel to aluminum"
"the aluminum front sub frame swap versus the steel on the 63-82 frames"
-aluminum rear diff that incoporates the diff front mounting bracket into the casting.
- aluminum rear cross member for the diff to frame mount.
- I do believe the steel in my 80 frame is thinner is some areas as it would bend when using a jack on the side frame rails. The car has no rust so I know the metal is like original. I cut out the bottom of the frame rails and welded in thinker steel
- no changes to the front frame/sub frame that I'm aware of
