Steeroids Manual Rack and Pinion Conversion Issues
I chose the manual unit because it did not require any change when converting over from SB to BB which I plan in the next few years. I know it was done back a$$wards to a point. A reputable shop had my car, so I started adding stuff while it was apart as the labor was less. My car is a factory manual steering car.
Has anyone had any issues with this conversion?
I had to clearance my header tube next to the steering u-joint, as many others have with this conversion. After getting it bolted up, it turns out I needed to do a little additional but minor clearancing of the header tube; the lock screws were still just making contact at one point. It was so minor it was only noticeable at idle or very low RPM, when the assist was low. I was trying to minimize the ding, and just didn't go far enough initially.
Another possibility is the U-Joint isn't completely aligned/in phase, but I would also look for rubbing somewhere.
Two universal joints (and in the Steeroids case - three universal joints) can result in large torque fluxuations as you rotate them through 360 degrees. Not having the transmission and differential drive shaft joints phased properly can result in very annoying vibrations in your drivetrain. The vibrations are caused by torque variation. This is with a two joint system. A third joint only makes the system even more complicated.
I am sure that major automotive companies probably have computer programs that can calculate the phasing for minimum torque variation. I don't have access to that type calculation.
One last thought, check to make sure that one of your three universal joints might be bottoming out (exceeding its design angle) and going metal to metal at some point during the rotation of your steering wheel.
Jim
For me that meant the sticker on the u joint that connects the the steering shaft faces straight up. The lock nut doesn't go on the flat part of the shaft like you would expect.
Also make sure you are not making contact with the frame/engine mount. I had to grind off about 1/4 in order for the key to not make contact during ration. You could feel the bind with every full turn.
