Would this column work in a 68 conv?
Old Jun 16, 2014 | 12:17 AM
boynton6spd's Avatar
boynton6spd
Default Would this column work in a 68 conv?
http://www.ebay.com/itm/28-Chrome-Steering-Column-Hot-Rod-Tilt-Manual-GM-No-Key-New-Floor-Shift-/191147545492?pt=Vintage_Car_Truck_Parts_Accessories&vxp=mtr&hash=item2c81481394
Old Jun 16, 2014 | 02:54 AM
terrys6t8roadster's Avatar
terrys6t8roadster
It does not have the lower mounting plate to the fire wall. My 6t8 has a spline for the rag joint, also cannot tell about the steer wheel mounting. I would say no. T
Old Jun 16, 2014 | 04:18 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
You really need to measure from the steering wheel to the firewall to make sure that the column you buy will be long enough to stick into the engine bay so that the rest of the hardware can be attached.
The new column should be several inches LONGER than your measurement.
Like Terryroadster said....be careful of what you buy, or you may spend even more money getting adapters so that you can attach the new column to the steering box.
Old Jun 16, 2014 | 06:09 AM
aussiejohn's Avatar
aussiejohn
Default Who made it???
boynton,
Number One thing to do is find a manufacturer's name on it. If it is not ididit or Flaming River, walk away. There have been a number of Chinese tilt columns made (and sold in the USA by "American" companies) with VASTLY inferior tilt "knuckles" (compared to what GM put in THEIR tilt columns). These have been specifically banned in New Zealand because of their high potential to fail when placed under load.
New Zealand only allows for sale the ididit and Flaming River tilt columns, as they use GM tilt mechanisms or products at least as good as GM parts.
At the price being asked, can you really believe that it's made in the USA?
Caveat Emptor.
Regards from Down Under.
aussiejohn
Old Jun 16, 2014 | 06:22 AM
Jim Shea's Avatar
Jim Shea
Default Aftermarket Steering Columns in 1967 and all C3 Vettes
My thoughts on the subject.
http://jimshea.corvettefaq.com/?p=891
Jim
Old Jun 16, 2014 | 09:35 AM
boynton6spd
Thanks for the answers...I'll stick with ididit or flaming river!
Old Jun 16, 2014 | 09:43 AM
1Fordman's Avatar
1Fordman
I put an Ididit in the 68 and am very pleased with it. One drawback is being non-collapsible you cant do the Borgeson conversion, as it reqires the column to be collapsed 2".
And as Jim Shea pointed out you also don't have the safety factor of the collapsible column.
To Would this column work in a 68 conv?
