Accessory Power
Old Jun 19, 2014 | 12:24 AM
68Thunder427's Avatar
68Thunder427
Default Accessory Power
Where is the easiest place to get accessory power from ie with the key in accessory position? I am assuming the fuse box but why not ask the experts.
Old Jun 19, 2014 | 01:15 AM
Peterbuilt's Avatar
Peterbuilt
Yes, at the fuse box at the terminal marked ACC
What are you hooking up?
Old Jun 19, 2014 | 07:55 AM
68Thunder427
A small stereo amp.
Old Jun 19, 2014 | 12:11 PM
Richard454's Avatar
Richard454
Just about all stereo amps have a trigger wire AND a power wire.
The trigger wire takes very little power- and is usually connected to the power antenna lead or if not available (say a stock radio) you could use switched source-such as Peter pointed out on in the previous post.
For the POWER wire of the amp- I really don't recommend going to the fusebox- go to the battery. You are asking for problems AND will more than likely bring alternator noise ( an annoying whine that changes pitch w/ RPM) into the system.
Richard
Old Jun 20, 2014 | 12:14 AM
68Thunder427
Richard
Power wire is already ran to the battery (I agree) and was just curious on the accessory. The ground is also ran to the battery. Temporary test with the motor running and NO annoying whine / engine noise
Old Jun 20, 2014 | 08:49 AM
flyeri's Avatar
flyeri
By connecting trigger wire to antenna or amp wire on radio you will only power amp with radio on. On ACC you will power it anytime switch is on.
To Accessory Power
