Four Barrel Engine??
Old Jul 23, 2002 | 06:32 PM
bsowa's Avatar
bsowa
Default Four Bolt Engine?? Not Barrel
Not Barrell,.....bolt, sorry, was reading about carbs and typed in the wrong word
What is a "four barrell engine" was told that the engine was replaced for a 4 barrel....
[Modified by bsowa, 1:53 AM 7/24/2002]
[Modified by bsowa, 1:54 AM 7/24/2002]
Old Jul 23, 2002 | 06:42 PM
NHvette's Avatar
NHvette
Default Re: Four Barrel Engine?? (bsowa)
Four barrels in your carb.
All 76s had a 4 barrel carb. Maybe they meant that they replaced the
original with a performance (like a Holley) carb.
If there was EVER a 2 barrel - then that was the ultimate bubba (mickey mouse). :rolleyes: :mad :confused:
You can check the VIN # against the number on the front tab of the
block, to see if it is the original L82 engine. L82 was factory performance
option. This can also be verified by the VIN # - but forget which digit tells -
and left my book at home. anyone know ??
Good luck - and have fun - you came to the right place to read and learn.
Don't forget to wave... :seeya
Old Jul 23, 2002 | 06:48 PM
Larry B.'s Avatar
Larry B.
Default Re: Four Barrel Engine?? (Daves_rusty_75)
NO corvettes EVER had a single two barrel carburetor.
Old Jul 23, 2002 | 07:08 PM
75Rag's Avatar
75Rag
I think we might be talkin' 2 BOLT or 4 BOLT here, not Barrel. What is it this person told you, can you give more information about the context of the conversation? :confused:
Old Jul 23, 2002 | 07:13 PM
daily_driver's Avatar
daily_driver
Default Re: Four Barrel Engine?? (75Rag)
make sure nobody steals your extra 2 barrels/....
its located right next to your flux capacitor.
Old Jul 23, 2002 | 07:31 PM
BigBadRed's Avatar
BigBadRed
Default Re: Four Barrel Engine?? (daily_driver)
Must of been an old timer. See back in days before money, we used to haul around barrels of booze. Could be wiskey, could be burbon, or if you were down on your luck, maybe just a barrels of hooch.
Well some folks just got the cheaper 2 barrel engines. you see, that would only cost ya to barrels of booze. Well, four of the hooch. But then you would say your engine is a hooch scoot and noone liked saying that. But if you got your self a good engine, then that would cost you 4 barrels of booze.
clear?
--marc
:D :D
Old Jul 23, 2002 | 07:34 PM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
i think barrel is an old english form of measurement just like a yard or bushel or furlong. just like the standard SBC 350 is a 5.7 liter, well, there is a barrel equivalent. ;) i'm not sure what the liter to barrel conversion is but i'm pretty sure that a four barrel engine is pretty big! :lol:
Old Jul 23, 2002 | 07:39 PM
daily_driver
Default Re: Four Barrel Engine?? (clutchdust)
they measure oil by the barrelll....
i thnk its like 50 some gallons to 1 barrell!!!
in that case, thatd be a @#@@ huge engine!!!
wowowow!!
:eek: :eek:
Old Jul 23, 2002 | 07:41 PM
Sharky Guam's Avatar
Sharky Guam
Wait a minute!
I have a two barrel carb on my vette. And it is factory installed.
Let me rephrase that....I have three, count them, three two barrel carbs on my vette!
:yesnod: :yesnod: :yesnod: :yesnod: :yesnod:
:lol: :lol: :lol: :lol: :lol: :lol: :lol:
Old Jul 23, 2002 | 07:45 PM
daily_driver
Default Re: Four Barrel Engine?? (Sharky Guam)
i stand corrected!!!
i had to look it up
Barrel [42 gal]
Quart (qt) 168
Pint (pt) 336
Old Jul 23, 2002 | 08:18 PM
wcsinx's Avatar
wcsinx
try ... http://www.idavette.net/facts.htm
Old Jul 23, 2002 | 08:32 PM
Robert N's Avatar
Robert N
Default Re: Four Barrel Engine?? (wcsinx)
We had a one in an old honda:
4 barrel, 8 mouse, O HP :D
Old Jul 23, 2002 | 09:52 PM
bsowa's Avatar
bsowa
You are right....it now has a 4 bolt. Sorry for thew confusion. I was reading about carbs when I made the post, hence I typed Barrel.....not bolt. So....what is a 4 blot....
Old Jul 23, 2002 | 10:13 PM
Darkness's Avatar
Darkness
How come it was a 2 bolt and now its a 4 bolt???
BTW there are 2 types of barrel measeures:
Barrel (US liquid) = 31.5 US gallons
Barrel (crude oil) = 42 US gallons
Paul
Old Jul 23, 2002 | 10:17 PM
bsowa's Avatar
bsowa
Default Re: Four Barrel Engine?? (inferno-vette)
I have no clue.....All I was told that the engine was replaced and it now has a 4 bolt. What is the difference?
Old Jul 23, 2002 | 11:18 PM
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
So how many cubic inches in a barrel. Multiply that by 4 and you have ... a really really big engine. :lol:
Seriously... 4 barrels is the carburator and 4 bolt is how many bolts hold each cap down on the crankshaft. Some engines are 2 bolt... 4 bolt is stronger and usually (if not always) found on high performance / high horsepower engines.
Old Jul 23, 2002 | 11:32 PM
glen242's Avatar
glen242
If it was a real L-82, the factory engine would have been a 4 bolt. refering to the number of bolts used to hold the main bearing caps on the engine.
Check your VIN# on the windshield pillar, drivers side. In '76, if the 5th digit is an X then it was an L-82. If the 5th digit is an L then it is an L-48. (1Z37 L or X)
To Four Barrel Engine??
Old Jul 24, 2002 | 02:20 AM
Stevo81's Avatar
Stevo81
Default Re: Four Bolt Engine?? Not Barrel (bsowa)
I just saw a 12 volt rear end in the paper. I called but it was gone. Hmmm :crazy:
Old Jul 24, 2002 | 07:38 AM
daily_driver
Default Re: Four Bolt Engine?? Not Barrel (Stevo)
he said 12 volt rear end hehehehe
Old Jul 24, 2002 | 04:41 PM
IronJen's Avatar
IronJen
Abby Normal
bsowa, there is virtually no difference in the basic engine between a two bolt and a four bolt except the three center crank main journal caps. a standard, two bolt block will only have two bolts for all five main journal caps. one on either side of the cap. a four bolt block has been machined slightly differently in that the three center caps are made a little more broadly and both the cap and block are drilled and tapped for four bolts, two on either side. the front and back main caps on all factory small block chevrolets are two bolts. BB chevys are a little differnent in that i've seen BB with 4-bolts on all five main caps. a two bolt block can be machined to accept four bolt main caps but unless your putting 350+hp to the flywheel, i don't really believe it is necessary and could arguably weaken the block.
as for difference in performance that is as different as one day is from the next. you can put the same components from a 4 bolt engine into a 2 bolt engine and vice versa. back to the issue of the block though, it is commonly accepted that a 4-bolt block is capable of handling more power than a 2-bolt but i believe that the power levels you would be talking about are bordering on an unstreetable engine.
