Question on valve stem seals
Old Jun 23, 2014 | 03:29 PM
jim-81's Avatar
jim-81
Default Question on valve stem seals
So I'm thinking of replacing the valve seals. I've got some mild oil usage and smoke at startup, and burning oil smell when running. I thought I'd start with this. I'm looking up valve stem seals on Summit and there are some specs that I'm not sure of.
My engine is a GM crate motor (from PO) about 7 years old, not sure on the specifics, but about 290 or 330 HP. I think the heads are the not-so good 462624's (from what I've heard).
Here is what I am looking at:
http://www.summitracing.com/parts/fel-ss72526
and intake:
http://www.summitracing.com/parts/fel-ss72527
Are these correct? Thanks
Old Jun 23, 2014 | 06:14 PM
yyz1970's Avatar
yyz1970
I did mine a few months ago I used the umbrella type (#7526) on both intake and exhaust
Old Jun 23, 2014 | 08:27 PM
GUSTO14's Avatar
GUSTO14
Either one should work. The first set includes the "classic" O-Ring seal GM used for decades on SB Chevy's. They're not really necessary if you're using umbrella seals, but, it can't really hurt.
Back in the 70's a popular choice was to use "Vega" seals. Very inexpensive, long lasting and very effective.
Good luck... GUSTO
Old Jun 23, 2014 | 11:06 PM
yyz1970's Avatar
yyz1970
I would start with a compression test
if the bottom end of the motor is bad valve seals are a waist of time
Old Jun 24, 2014 | 04:06 AM
FireballXL5's Avatar
FireballXL5
Mine has the umbrella valve seals on intake and exhaust... No o-rings on the two we pulled... And I had this split in the intake seal pictured...
So far I only replaced that one set on cylinder 7 which was the one I had fouling plugs...
At the moment , I'm still getting a puff of blue on startup... Not sure if I have another similar issue... Will be watching the plugs closely...
Old Jun 24, 2014 | 07:16 AM
jim-81's Avatar
jim-81
huh... it says, those are for exhaust only...
Old Jun 24, 2014 | 07:17 AM
jim-81's Avatar
jim-81
I did that about a year ago and they came out ok, around 135 - 140 psi if I remember, and pretty close. But I'll do another one.
Old Jun 24, 2014 | 11:51 AM
FireballXL5
The umbrella gasket is better, sees higher temps, and I guess it's not that uncommon for guys to run them on both sides.. My 383 came that way... And, when using the umbrella, they say the top o ring isn't necessary... And that info came from an experienced corvette shop builder mechanic... I trust his expertise
Old Jun 24, 2014 | 11:57 AM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Umbrella seals are the trick to buy you some time until you can fix it permanently with a valve job. If this has been going on for some time then there will be enough burned oil buildup on the valve stems that the seals won't help much. But it will help.
Old Jun 24, 2014 | 04:35 PM
FireballXL5
That's what I'm wondering... I had that cracked seal on the motor when I bought the car from the PO... 254 miles from him... 5500 miles from me on this engine... Just replaced the seal, about 500 miles ago... Was still getting a little puff on cold startup... But it 'may' be getting better? Perhaps I had sooty deposits on the valve? I'm waiting to see if it burns off/clears up, or if I need to delve deeper into the heads etc... Too bad too, cause it's all fresh/new under the hood...
Old Jun 25, 2014 | 09:36 AM
jim-81's Avatar
jim-81
yeah, I hope I don't have too much gunk in there from it being this way for a while...
Old Jun 25, 2014 | 10:42 PM
7T9Shark's Avatar
7T9Shark
Is there a post that tells how to replace the seals? I might do mine, too.
Old Jun 26, 2014 | 12:27 AM
FireballXL5
Could be... There are numerous YouTube vids...
You will need a valve spring compressor, compression gauge capable of hooking up air to fill the cylinder, a small hammer, and safety glasses... Get it apart, pull one of yours off, and make sure to get the right size to put back on... A caliper could be handy to measure your stud where the seal sits, they come in numerous sizes... A magnet is handy to retrieve the keepers...
Adjusting valves or rockers depends on lifters and rocker arms when done...
I had a shop do mine on one cylinder... And I'm confident I could do it myself... But I didn't have the tools... And it pays to have someone with experience breeze through it!
To Question on valve stem seals
